Wipers go off uneven...anybody else?
Is it normal for the right blade to start moving before the left blade...or is my blade just having trouble keeping up?? Thanks for any responses in advance.
CTS-V Import Slayer
Sometimes this can mean that the main hold-down bolt that is at the base of one of the arms is not properly tightened or has come loose. You might start by checking this first. Without looking and by memory totally...just follow the wiper arm down to the main axis where it attaches to the "nub" and there is likely to be a black cover that either removes totally by pulling or swings to the side (sorry....I'm not going out to look right now) and there will be a bolt there that attaches it securely to the splined output shaft....make sure both of those bolts are tight. If so...then the problem is likely in the linkage somewhere and the dealer will have to mess with that for you.
CheeseyPoofs McNut
10-11-2015 11:25 AM
