Window washers not working
Hey all, ,
So as it states window washers not working. That's not completely true. What's happening is there's almost no pressure on the window washer nozzle driver side and no fluid coming out of the passenger side. I can hear the motor running and there is a bit of washer fluid coming out of the driver side not quite enough to make it to the window. Do I have a broken line or a bad motor. Also doing my plugs. I am putting in NGK spark plugs 6994 iridium, and I believe the torque spec is 13 foot pounds can you please confirm this. I know the strut mounts or 21 foot pounds. Short sweet and to the point. Yes I did search and that's where I found the 13 photos. Just would like to confirm I am also definitely using anti-seize.
Yep, 13 ft-lbs with anti-seize...
Sounds like the fluid line between the reservoir and where the line splits is pinched or blocked, or there is debris in the reservoir interfering with the pump.
