Window stops going up
Hey guys hoping someone can help me out...my driverside window no longer goes all the way up on its own. If the window is down halfway it'll go up but when i put the window alll the way down and try to put it up it stop about 3/4 of the way up...and the times it may go all the way up it go up and then come back down a bit... Any suggestions????????
Dogmatic Dinosaur
Go and get some Shin-Etsu grease (around $15) from an Acura or Honda dealer. Take a towel in a flat-head screwdriver and clean out the back groove of the window. Once it is clean, then put a nice layer of Shin-Etsu on there to lube it up. Put the window up and down a couple of times and it should be better. Worked on both of my TLs.
If it is really bad, then take the door panel off and lube up the tracks.
If neither of these things work, post... you might need some new parts and we can help you out.
This is the same grease that you can use for your sunroof tracks and lots of other things.
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
