Why do I not get oil pressure immediately at startup with S2000 size filters?
okay so i thought it was the weak amsoil anti drainback valve but well, just changed to purolator blue one i got really cheap, and still has the same problem.
car has been fine with stock size amsoil filter with the oil pressure light going off immediately when starter stops and rpm soars to 1200
is it because the filter's "bigger" it has to fill more before car sees some pressure?
US Navy Seabees
I guess I have to ask, why are you running a Honda S2000 filter instead of a TL filter?
the overexplainer
the theory is there's more flow, filter media, and more volume with the s2k filter.
people with different hondas have also been using them as well for some time.
Just how long do you have to wait for oil pressure? a split second?
soooo.... i did have a bad bump-stopping thud while running the S2000 filter but there's no leak and i'm leaning toward the sensor failure???? is it common? @ 110k miles?
AZ Community Team
Received 7,770 Likes
Difference in total volume (NOT including filter media, i.e. the volume of the 'can' only) is fairly small .... 5% or 7%, iirc .... ?? There's a thread where I posted the cylindrical volume of both.
I've run the PCX-004 for all but the first two oil changes. I've never noticed the oil pressure staying on long enough to notice.
Thanks bearcat @ ez. here's a video
now that you say it it adds a bit of peace of mind, but it used to go away as soon as the tach flinched... and maybe if it was like that since i got it, i'd be like "oh it's just this car" but,,,
people suspect oil pickup?(strainer) ugh i do not wanna take the pan off.... :/
HydrasunGQ
09-14-2015 10:14 PM
Mugen TSX
Eastern Canada
09-01-2015 11:05 PM
