Whats this sound my car makes? *video*
whenever i go over speed bumps or a big dip in the road it starts making a squeeking noise. here is a video of me going over speed bumps two times
http://www.youtube.com/watch?v=fs465afXG2I
The squeeky sound?
I had something like that on my GMC envoy and it was from my upper control arms. I just had to grease them up a bit.
or could be shocks?
Go over the speed bump one wheel at a time and see if its on one side only..
also push down on the car on one side only and see if you hear the noise. Might be able to isolate it more.
or could be shocks?
The squeeky sound?
or could be shocks?
or could be shocks?
Sounds a lot like swaybar bushings.
I managed to replace mine (stock) without taking the bar off or lowering the subframe. It was a real pain but doable. You can try and squirt some grease in the bushings with one of those small syringes or replace the bushings.
If you replace them and if they say they must remove the swaybar, you might want to look at upgrading the swaybar while you're in there since a Type-S front bar is under $40. Of course you would have to upgrade the rear bar too to balance it out.
The easiest test would be to remove the endlinks on the swaybar and wire it up out of the way. If the squeak goes away it's the swaybar.
also....is this a problem that i would have to fix immediately?
Make sure to have them diagnose it first. I think it's the swaybar bushings but I could always be wrong.
I'm not sure of the labor but if they say they have to drop the subrame and partially remove the swaybar, don't be surprised if they try and charge you a few hours of labor. I did mine without dropping the subframe or removing the swaybar and I actually installed poly bushings on the stock bar but it wasn't fun.
You can let this go forever and it will never cause a problem. It's annoying but that's it, no problems.
Phambam12
09-05-2015 04:10 PM
Mugen TSX
Eastern Canada
09-01-2015 11:05 PM
