04 Acura TL gets hot when at a stop and fans only come on very low only whevehicle of
Old 07-09-2019, 09:40 PM
Christina Hernandez's Avatar
My 04 TL is getting hot when at a stop and the fans only turn on when the car is off but very low
Can u help me regarding this?
Old 07-10-2019, 01:13 PM
Chapter Leader
(Northeast Florida)
gatrhumpy's Avatar
Received 1,651 Likes on 1,116 Posts
When the car cools down, you should check the coolant level. In addition, check to see if there are coolant leaks under the radiator. Check the big black radiator hoses for leaks as well.
Christina Hernandez (07-11-2019)
Old 07-11-2019, 08:49 PM
I checked the coolant and everything is good but I noticed only one fan comes on but
What if I hook them up direct or to a switch will that make the fans turn on??
Old 07-12-2019, 10:09 PM
USNA93's Avatar
You mean your AC?
Old 07-14-2019, 01:15 PM
01acls's Avatar
Possibly low on coolant and/or air in the system or coolant leak. If not then replace the radiator and thermostat.
Christina Hernandez (08-26-2019)
Old 07-15-2019, 01:18 PM
Chapter Leader
(Northeast Florida)
gatrhumpy's Avatar
The fans are wired to a thermostatic switch that come on after it reaches a preset temperature. Bypassing that could kill the battery.
Old 07-22-2019, 09:44 PM
Ok I checked for leaks there's no leaks, and are both fans supposed to be on or just one? Are both fans supposed to cool down the engine? And where is is the thermostatic switch located at?
Old 07-22-2019, 09:50 PM
What can be making my 04 TL get hot
I've changed the thermostat and radiator cap what else could be getting it hot?
Will Y. (07-23-2019)
Old 07-22-2019, 10:35 PM
Administrator
Ron A's Avatar
Received 1,002 Likes on 572 Posts
This post/thread has been moved from the Car Talk Forum to the model specific forum for better response.
Christina Hernandez (07-22-2019)
Old 07-22-2019, 11:06 PM
peter6's Avatar
1. No coolant in the system - remove cap only when engine is cold and refill it if it was low. If it was low it must be going somewhere. Find the leak and fix it.
2. No coolant flow - damaged pump, bad thermostat, or clog in the system. When engine warmed up (make sure it's not overheating) touch upper and lower radiator hoses. Also touch radiator. If all of them are (Very) hot then there must be flow. If at least one is really cold investigate.
3. Fans are not working. Car would usually overheat when standing but when driving it would be more or less fine (as some air would be forced through the radiator). Seems like your other thread mentioned some problem with fans. Did you fix it? If not then try to describe the problem more (like what you see fans doing?).
4. Unlikely here, but sometimes radiators are damaged but they don't leak - for example most of the fins are either missing or bent, so air can't get past them thus causing overheating.
5. If setting climate control on HIGH, will it help with cooling the engine?
6. Bad temperature sensor - car is not actually overheating. Use some other thermometer (like IR one) and point it to the hose/radiator. If car is boiling coolant (and dumping it to the reservoir) then it must be overheating.
Old 07-23-2019, 01:29 PM
Jackass's Avatar
The OPs other thread covers some of this and I think the focus was on the fans.
03tlswfl
02-12-2019 06:09 AM
inkonspikuos
02-01-2008 03:41 PM
projectsx
01-15-2008 02:39 PM
Zapata
06-04-2003 06:13 PM
Quick Reply: 04 Acura TL gets hot when at a stop and fans only come on very low only whevehicle of
