Weekend adventure!
Weekend adventure!
05 TL 113k, 100k serviced performed 8k miles ago.
I drove to Killington VT from NYC this past weekend with absolutely no problems. I arrived on Thursday pm, parked the car and drove it again on Friday am, keep in mind the temp was about 2 degrees and a wind chill of -25. The car started with no trouble, i drove a few miles and decided to get some gas filled it up with premium gas as usual, picked up some ski gear and drove back to the condo. I tried to start the car 9 hours later to no avail. Cranks over, no warning light and everything sounds normal. I didnt want to kill the battery so i decided i would try again the next morning. Still no luck. I had the car towed and then called them later that afternoon and they said all they did was roll the car in the garage and it started fine and showed no signs.
I put some dry gas in and went on my way.
Driving back to NYC the car was fine, but now i have a check engine light on and need to get that code read.
Obvious thing would be that there was moisture somewhere which froze. But the mechanic said they had only rolled it in and started it 5 minutes later.
Any help from the forum would be much appreciated.
