Way to reset the Driver 1 Settings
Ive noticed that with the Driver 1 key the car auto locks when i get in the car and when i hold the unlock button the windows dont go down. This didnt happen till recently and it wasnt a problem before. I put the driver 2 key in and everything works how it used to. So is there a way to just reset the Driver 1 key and/or settings...and yes ive gone through the "Keyless Settings" on the dashboard and it doesnt fix anything!
From what I remember think you have to press the Lock and Unlock buttons at the same time. Turn you Keyfob around. The instructions are on the back on how to reset your memory setting.
After you set everything the way you want it are you pressing the memory button and then number 1 button on the drivers door? It should flash after you press the number 1 button indicating it took the changes.
rockyboy
12-06-2022 02:29 PM
braveheart
09-07-2015 08:12 AM
