Vtec Rocker Arm Oil pressure sensor circuit high voltage stuck on help please!!!!
I recently replaced my vtec oil pressure switch and that did not help at all and it’s still saying Vtec Rocker arm oil pressure sensor circuit high voltage stuck on please help what do I replace because my vtec is not engaging it won’t go past 3500 rpms
how's your Oil level?
I’m going to replace my variable camshaft timing solenoid because I already replaced my oil pressure switch and that didn’t help it at all the next thing is that camshaft timing solenoid
How much oil did you add when you changed it?
