vibration under gas pedal
Sometimes, i feel a vibration under the gas pedal when im on first gear and at a low rpm then when it cganges gear it doesnt happen anymore. anyone else has this problem?
I think this is the same problem as the 1500 rpm vibrations. I have it as well as many others. I also have the vibration where the car is at a stand still and i put in little throttle and there is vibration which is below 1000 rpm and on to the 2000-2200 rpm vibrations. Im getting sick of it and i thought i can deal with it at first. And because there seem to be no fix at all but im going to bring it in to see what the dealer says
re
has anyone gotten this problem fixed?
Automatic transmission here:
Only happens when the car shifts from 1st gear to 2nd gear at low rpm's, you feel this pretty bad clunk noise when your foot is on the gas pedal and when it is between shifts.
Yes I have the same problem. I just bought a 04 with 78k miles last month. Its like a vibration/scrape in the gas pedal and its last only about 1 second. I'm not a car expert but I feel like the transmission is crappy on this car and it might be a tranny problem. I've been searching everywhere for a thread like this and I don't see a solution. Someone give us answers!
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
