Vibration
Old 11-08-2010, 08:50 AM
Luger's Avatar
Vibration
Hopefully you guys can offer some help.
06 MT
I had some vibration in the front not but now it got worst. The delaer said the tires are cupped but over the last month the vibration has gotten worst. I have yoks W4s stock rims. I was told the rims are fine, but i get loud tire whirring noise on the highway.I also take the car out of gear and can feel it in the steering and dash but feel it more once i put the car back in gear (50-80 mph). The cv boot was ripped on the passenger side and they replaced the passenger cv joint. The car felt more stable better planted for a few days after that and now it is back to the vibration not handling as well. Could this be compliance bushing , drivers cv joint, or possibly the bearings. I also feel the vibration when i make a right turn from the front left wheel and feel like the suspension is "binding at times" from the same place?
Any other ideas?
Old 11-08-2010, 09:16 AM
Registered User
rbf351's Avatar
i have the same thing, except i have an 06 Auto. at first i thought it was a balance issue, had the car balanced, and it fixed the issue a little. then had all 4 tires replaced, and balanced again. that made the problem a drop better. then about 5 days later it went back to the same vibration when you get to about 40 MPH, and gets worse as you get faster. Braking makes it even worse, so i replaced the rotors. then replaced them again a few days later, and still the same issue. now i have a tiny whine when i accelerate slowly.
i'm starting to guess the issue is in the tranny
Old 11-08-2010, 09:22 AM
Luger's Avatar
Rbf,
I was thinking the same thing, last I checked they said the mounts were fine but I do notice when i get more vibration the car doesnt go into gears as smoothly when I shift was well. Also since they removed the joint maybe the tranny angle was affected. I will have to see but i dotn think they will be able to diagnose it probably get the same tire or they cant duplicate crap.
Old 11-08-2010, 09:27 AM
Registered User
rbf351's Avatar
Originally Posted by Luger
Rbf,
yeah thats typical from acura, they can not duplicate anything. my car has been out of warranty for close to a year now, so i do all the work myself. i'm just hoping it's not the tranny, and something simple as a wheel bearing which i'm sure it's not
MrHeeltoe
20
02-23-2023 01:54 PM
joflewbyu2
10-08-2015 11:16 AM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
thisisnotdave
4G TL Problems & Fixes
09-08-2015 10:02 AM
Quick Reply: Vibration
