Transmission park to reverse
Old Aug 10, 2016 | 09:23 AM
Luisua6's Avatar
I got home last night and I parked my car 05 automatic Acura TL on my driveway which is at an incline when I went to put it in park it did a grinding noise. Has anyone experienced this? Or know what the issue is? I am thinking transmission mounts or something is going wrong with the transmission which is changed a year ago.
Old Aug 10, 2016 | 03:41 PM
csmeance's Avatar
Check your transmission fluid level! Low fluid level + Incline can cause a grinding noise. Do you use the parking brake at all when parking on inclines? When was the last time the trans fluid was replaced? How many miles on this new transmission?
It certainly can be bad transmission mounts or engine mounts but there is a lot to go though before we can pinpoint the cause of the noise.
Old Aug 10, 2016 | 03:53 PM
Luisua6's Avatar
I started using the parking brake and it has gone away
Old Aug 11, 2016 | 10:11 PM
csmeance's Avatar
This would point to worn motor or trans mounts, or worn axle joints.
Old Aug 11, 2016 | 10:13 PM
Luisua6's Avatar
I am thinking transmission mounts I just changed all the motor mounts just last month.
Kolomango
3G MDX (2014-2020)
Jul 15, 2016 08:55 PM
AlexanderTheOkay
May 27, 2016 04:50 PM
qwxilvr
5G TLX Problems & Fixes
May 7, 2016 02:35 AM
Evilocity
Apr 22, 2016 09:33 AM
DJMikeT
Jan 27, 2016 12:03 AM
