Transmission messed up
A Black TL
WHen i switch from p to r then to d. The car makes a loud noise. And it shakes a bit, sometiems alot. I have 08 TL, with only 4k miles/
why even bother posting here? it's under warranty take it back to the dealer and have them check it out
Make sure you come to a complete stop before switching gears. If you do this and still have a clunk, check your motor and transmission mounts to make sure that one isn't broken/cracked.
Who cares what it is- its a brand new car!!!!!
Call the dealer and ask for first appt- you have bad transmission noises!
They will send the tow truck if you want
Even new cars suffer from bad part or improper assembly- you know they build everythig on the cheap and as fast as possible-right????
things break - thats what the bumper to bumper first year warranty is about-
Turd Polisher
Maybe he's been doing Neutral > D5 drops to get better burnouts.
the next member that bashes/insultes/pokes at the OP will get a vacation
A Black TL
no, i dont do N to D5, drops. I know how bad that is for ur transmission. And i only asked 1 time on how to do a burnout in my tl. And i still haven't and don't plan on doing a burnout.
Holding back my sarcasm per warning above lol, you probably have a broken motor mount.
Wheel hop from launching hard or burnouts, shifting before fully stopped, hitting the gas in neutral and shifting into gear. Pretty much anything that shocks the drivetrain. They usually don't break from normal service until they get very old.
Just take it in, it's a warranty item.
Stand next to the car with the hood up. Have a friend put it in drive and hit the gas with the brake and e-brake on so the car doesn't move. A couple sharp bursts or throttle is what you want and see of the engine moves a lot.
Then put it in reverse and do the same and see if the engine moves more, less, or the same as in drive. If it moves a lot in drive, it's your front mounts (assuming I've got this FWD thing down right). If it moves more in reverse it's your rear mounts.
The engine is supposed to move a little but if it's doing it enough to make a noise, it will probably be obvious it's too much. You may hear the noise outside of the car with the hood up or it could be an exhaust component hitting the firewall. Anything touching the firewall will sound very loud inside.
joflewbyu2
10-08-2015 11:16 AM
