Transmission line pressure tap - where is it located?
Old 08-03-2017 | 10:00 PM
ejleo's Avatar
3rd Gear
I'm hoping someone can help me locate the main Trans line pressure port since I can't find it to save my life. I have this pic below from the manual but there's no orientation. I thought it was near the 3rd/4th pressure switch but apparently not. I have a BYBA transmission. Thanks
Old 08-03-2017 | 11:50 PM
musiclevelz5's Avatar
Its located on the front lower area of the transmission. You can access it from underneath the front of the car after you take the splash guard off. Its the second from the bottom. The lowest one is for the low hold clutch. Then the line port is the next one up above.
Old 08-04-2017 | 12:19 AM
ejleo's Avatar
3rd Gear
Thank you Music! Appreciate very much
