Tpms
Tpms
After driving for a few miles the TPMS light keep coming on. Help me its annoying. I was thinking maybe one of the Tire pressure monitor things are not working.
Check your MID on your dash board. Also it will tell you your actual tire pressure then fill up yours tires to the proper PSI. I have nitrogen in my tires and it doesn't fluctuate with temperature differences. Also try reading your car Manuel or searching on these threads ...............
AZ Community Team
Received 7,771 Likes
If the display shows a constant "58" or "---" you probably have a faulty sending unit on that wheel.
On start up all 4 show "58", but go to the correct measured pressure within about 5 seconds beginning on the right front, then right rear, then left rear, then left front.
neuronbob
23
07-16-2019 10:48 AM
