TL couldn't start today!!
here in NYC we has our first real cold nights. Today my car wouldn't start. I can hear the engine trying to start, like normal, but it just won't start. i don't think its the battery neither. i didn't get to call Acura cuz i had to go to work right away, i used my girl's WRX to work.
just wanted to know how many people have had this problem and what is the usual cause????
could it be cuz of the weather? my girls WRX had this same problem too durin fall season and her car was brand new also. it just stopped happening to her car with no explanation. mine is an 05 TL with 12000 miles on it. service B display just went on also. need help guys, didn't expect engine problems from a TL.
Now with i-Vtec
Could be that your navi has been draining the battery. There was a recall for it. I got the recall notice for it in the mail. However, I will wait until I have the problem before getting it fixed because I don't like taking my cars to the dealership unless I absolutely have to.
were you low on gas and parked at an incline? this happened to my wifes RSX one morning when she parked the car on our driveway with very little gas left in the tank. i just had to roll the car down the driveway and the car started.
good luck!!
good luck!!
NAVI drain battery? i haven't heard about that. wouldn't the navi screen be on then?
good luck!!
good luck!!
na my gas if at half and not on an incline.
just started my car again today. and it started with a slight hesistation. but now its turning off and on ok, but its only been one day. gonna bring it to dealer tomorrow
Car Addict
1 Post
I have a 6MT TL, and the battery was dead today. We did hit like 7F yesterday. I have a portable jumper pack, which was almost dead too, but it jumped the car okay. But now my radio is locked. I had my NAVI replaced earlier this year since it was messed up. I will talk to the dealer at some point, I'll see how the battery does this week.
Same here
The same thing happened to me. It was about 38 degress out (according to the TL temp gauge), and my car wouldnt start. I attempted to about 5 times, but no luck. I finally gave it about 10 minutes rest, then went back out and tried again. This time, it sounded a little better, so i gave it some gas while turning the ignition, and it started up. Very wierd. Not sure if it was b/c of the cold temp, but it shouldn't be, I dunno. What did the dealer say bulacura?
my car battery dies all the time now. i only have 5000 miles on it and i have to jump it daily. it is completely dead but a jump gets it goin right away. btw im opn my second battery.
Well we it minus 10 Deg F 2 days ago and the TL started fine.
There is one thing with fuel injected cars that needs to be pointed out;
Maybe you already know this, if not here it is
When it is very cold outside
1-Turn the key to the On position without engaging the starter.
Wait 4 to 6 seconds with the key in the on position.
Then engage the starter.
By doing this, you are giving ample time for the gas pump to inject extra gas to facilitate starting (Fuel Injection's way of simulating a Choke on a carburator equipped engine).
Best regards
frenchnew
Best regards
frenchnew
2 batteries in 5,000 miles is not usual, there is something that is draining your battery. The dealer should be able to check this by connecting an Ampmeter to your battery (Between one of the battery post and the wire terminal connected to that post).
Have it checked by the dealer.
Best regards
Frenchnew
Same problem
I have non-navi and had the dead battery problem. I took it in and they replaced the battery (was dead), and performed recall - replaced fuse box. Now, my channel and volume controls don't light up on my steering wheel. I called and they told me the parts dept. screwed up, and they replaced w/ part made for TLs w/ Navi. I have to go back Wed. As it takes me over an hour to get to my Acura dealer, I'm going to push for a free oil change and possible file a complaint with the BBB depending on the service I receive.
A mistake was made in using the wrong fuse box (Navi vs. Non-Navi). This is hardly a BBB issue unless you have records of mistakes consistently made by this dealership's service department.
Even with a history of mistakes, I would approach the GM of the dealership and I would present my records to see why this continues to happen. If that did not produce the correct results, I would contact Acura Customer Service. The BBB would be my last option if the other two actions listed above did not correct the situation.
i have a remote start and nav dvd hooked up to my car. my dealer thought it was that but after talking to both installers they said they wanted to keep my car for a few days to run more tests. this is my second 05 tl. i had the same things installed in my last car with no problem. i hope i can get 31,000 for my car because il selling it as soon as i get it back.
my car is less than 2 months old and i have had some rough startups where its JUST manages to start up
its pretty cold up here in toronto - but ive never had this problem with my previous gen civic or 2g TL
man, honda is really letting up - ive started to notice soem rattles from the driver A-pillar too
orkoTL
4G TL Problems & Fixes
107
09-28-2017 09:12 AM
bearingman07936
01-07-2016 03:22 PM
