Tire Balance problem
I've not read anything in here about problems with the balance on the TL, but mines is going to shake itself apart soon.
I replaced the tires about 3 months ago with the same tires that were on it, General Exclaim UHP's. I bought them at Kauffman tire which is a pretty good shop in the GA, FL, and AL market. Ever since they were on, I have a bad vibration in the steering wheel over 70 MPH. I've taken it back to have it re-balanced and one shop said I need a high speed balance (to match the tire high spots to the rim high spots). Not sure if they did it or not, I just assumed they would. They also said something about a rough spot on the fron left hub that is causing the wheel to not sit flush. What the hell????
I'm taking it to another Kauffman tire to get looked at again. As I said, there hasn't been a balance prob since I had these tires replaced. Anyone have any insight?
I puchased a set of Yokohama Advan S.4 245/45-17 from a fellow I've been dealing with for 20 years. Had them mounted on chromed Acura wheels and had them balance using the cone 3 different times, then had them balanced using the "fingers" in the lug holes to be certain wheel perfectly centered. Still a slight vibration over 70, front and rear.
Annoyed, so I pulled the tires/wheels and took them to a local guy that has a Hunter Road Force machine. Best $50 I've ever spent. No more vibration.
Do the wheels spin true on the balance machine? Do you see any wobble or high spots?
If you decide to take the car to another location and pay to have it done again, be sure to let the manager know this before hand and let him know that once it's fixed, you're coming back for a refund on the balancing or credit on a future purchase.
<rant>
I hate it when shops try to wash their hands of anything that strays from routine without making a single effort to ensure the customer is happy. That really grinds my gears!
</rant>
邵樂百
That is a crock of shit. There's no rough spot on anything. And if that were the case, it would have shook before, too. They need to fix the problem. If there's a "rough spot" then tell them to make it smooth or do what ever they need to do to get your front wheels balanced properly.
<rant>
</rant>
<rant>
</rant>
had the same problem until i took my car and had my tires roadforce balanced on a hunter machine and also did the alignment with a hunter aswell, I dont remember my car driving this smooth ever. maybe when i just bought it i doest even shake a little at 100mph
Update!! I had the balance redone at another Kauffman tire. It was noticably out. It runs much better now, although there is still a tiny vibe at higher speeds. Sounds to me like the other shops machine is out of calibration.
Where can I get this roadforce balance? Anyone know of a place around Atlanta?
The DVD-A Script Guy
1fatcrxnem1
22
06-01-2018 01:23 AM
