Swapped factory hids and removed intake resonator now SRS light on..
I took my 2005 acura tl to the dealer,paid a tech under the table to remove my intake resonator and replace my factory hid bulbs with a set of 8000k ones.. When I got in the car and pulled off my SRS light was on did not have time to go back to dealer.. I heard sometimes this comes on if batt is disco?? Is there a easy way to reset it? If i GET A OBD scanner can I reset that way? Also this was weird but My driver side door lock just stopped working and I had to use the key to lock so I can set alarm. When I left the dealer it worked again and I have not had an issue since. I figured it was the actuator but maybe it was a loose fuse.. EXCUSE my spelling lol also this is my first post so sorry if I posted in wrong spot.. I tried to post pic but for some reason I cant on here
Did you remove the bumper? There are impact sensors in the front corners that could have gotten disconnected. Disconnecting the battery doesn't cause this to happen.
But once the SRS light comes on, you need to reset the system even if it's corrected or just a one time event. There is a way to do it by shorting out two pins on the under dash connectors. This can't be reset with a OBD II tool.
edit:
google acura tl srs reset. It'll give you some answers. I tried posting a link but it's filtered.
edit:
handsom-hustla
11-13-2015 05:04 PM
elietania
4G TL Problems & Fixes
09-05-2015 06:52 AM
