Sunroof issue...
On my 07 Type S recently when I go to tilt the sunroof open the drivers side mechanism will only travel partially leaving the right side open but the drivers wont budge. When I fully open the roof it will slide back normally but sometimes will intermittently stop closing. Any ideas? thanks.
Would be curious if you could get a video of it locking up or some pictures?
Did you check to make sure that the slides are greased? My old ‘01 CL-S sunroof used to stick and I put some grease on it and never had an issue after that. Not sure if same problem, but worth a shot. |
Did you try the greasing suggestion?
Greasy Fo Sheezy
