stupid question on A/S floor mats
Old Aug 4, 2009 | 01:26 PM
BlacuraTL-S's Avatar
NBP REPRESENT
How the HELL do you get the clips in the ALL season TL mats for the driver side? i feel like its impossible unless you make the holes in the mats bigger.......
"i cant get it in the hole..."
Old Aug 4, 2009 | 03:52 PM
RyanCHICL's Avatar
#GOBULLS
I can't seem to get the hooks into the holes either on my A/S mats. I just lay the mats over the hooks, they won't go anywhere.
Old Aug 4, 2009 | 04:10 PM
PhillyxMartin's Avatar
They hook its common sense I guess...you gotta do it in an angle.
Old Aug 4, 2009 | 04:14 PM
piggydog's Avatar
had to force it in to the point I thought I'd break it. Worse was pulling it off to clean it. After that I just layed on top of the hooks. There's no real advantage to hooking it in.
Old Aug 4, 2009 | 04:32 PM
JwongTLS's Avatar
I hope ur floor mats are off..maybe thats why its such a tight fit?
but it will fit..
Old Aug 4, 2009 | 08:58 PM
lariat's Avatar
Move the drivers seat all the way back,lift the rear of the mat and "angle" it in. That's all there is to it!!..
Old Aug 4, 2009 | 09:27 PM
NBP REPRESENT
i got it...took a pair of pliers and put it in the hole and spun them around and widened it just a bit...now they fit perfect...
Old Aug 4, 2009 | 09:43 PM
meowevil's Avatar
Sorry i guess i am noob but what are you guys talking about?
Old Aug 5, 2009 | 11:21 PM
shftl's Avatar
Mat Hooks
Lariat is correct. You put the seat all the way back and flex the mat so that its lower edge with the holes is almost upside down, insert the hooks, and then rotate the whole mat into position. I have left out the part about the cussing and the losing one of the holes and and then the other and starting over and more cussing.
The last time I took out the mats I looked carefully at the hooks. They curve up and back, and once the mat is in position it would be almost impossible for it to shift. I then realized that the barbs on the ends of the hooks were designed by Honda's liability lawyers, not the interior designers. I found that a small pair of wirecutters did a fine, neat job of clipping off the barbs. Reinstallation was a breeze. Counts as my second mod.
BoricuaTL
Apr 8, 2016 01:08 PM
acura_dipset_tl
Jan 1, 2016 03:02 PM
lland
Oct 4, 2015 04:47 PM
06TLMatt
Oct 2, 2015 08:14 PM
iesu3423
Sep 29, 2015 08:04 AM
