Steering knuckle replacement! help!!
hey guys! i have a 07 tl type s and i had a small accident by the front driver side! so i replaced the lower arm control and stud...but the front wheel is like tilted/ shifted about an inch to the back towards the fender/ door...so the mechanic told me that i need to replace the knuckle...so i ordered a new knuckle from acura but my question is how hard is it remove the hub and all the nuts and bolts from the old knuckle to the new?
excuse my ignorance
excuse my ignorance
Not an overly difficult job, but first check the upper ball joint as that can cause the problem as well as the upper arm and if the impact was hard enough, subframe damage can be possible.
The knuckle does not come with the hub assembly and bearing so that is also a problem as a machine shop is normally needed, but to remove the knuckle you'll need to remove the caliper, bracket, rotor, axle nut, upper and lower ball joint, tie rod end, ABS sensor.
ken953 (05-29-2013)
The knuckle does not come with the hub assembly and bearing so that is also a problem as a machine shop is normally needed, but to remove the knuckle you'll need to remove the caliper, bracket, rotor, axle nut, upper and lower ball joint, tie rod end, ABS sensor .
the overexplainer
I think he must mean the LBJ, there shouldnt be any problems transferring the rotor, caliper, etc those are all just bolt ons.
I just had my LBJ replaced from a botched axle DIY and they had to remove the whole knuckle out to press it out/in.
marcelft
07-10-2018 06:17 PM
