SRS Code 8-1 & 8-5 "Internal Failure Of SRS or Supplemental Restraint System Unit"
Hello my fellow acura members, I have an 2005 acura tl w/nav and recently got into a smaller bender /curb hit on my pass front tire. My driver wheel bag & pass seat bag & curtain deployed. i did replace all bags and as well as had the srs unit/module cleared crash data at BBA Reman in taunton,ma "i took personally and pick up same day". the seat i just replaced with a new seat but in the process i swapped out the opds and place my original one in too avoid an issue, and as well as replaced 2 front impact sensor and 2 pass side impact sensor "new from acura". my car never had any lights on prior too the curb hit and now it just has the annoying srs light on. i have to cleared the srs unit with the mes connect and as well bought a personnal craftsmen abs srs codeconnect scanner "fyi it wasnt cheap one,$350 for it''. the only codes im receiving is the "8-1 Internal Failure Of SRS or Supplemental Restraint System Unit" and "8-5 Internal Failure Of SRS or Supplemental Restraint System Unit". i also purchased another SRS unit/module out of a running 05 tl with no lights on i seen personnely as well and still received the same code with another srs unit/module. has anyone else had this issue? If so how did you fix it? im pretty tech savy so plz HELP and inform me guys thanks!!
Same here I payed some kid to clean out my car so he took the seat out playing music from the car and put the seat back in the car and now codes 8-1 and 8-5 reset it a million time still come back
mada51589
05-03-2022 08:54 PM
DiamondJoeQuimby
09-10-2015 11:40 AM
