Squeaky Wiper Blades
Local dealer replaced wiper blades on my 2006 TL but they are still squeaky when the wiper reaches the top of the windshield. It is very annoying.
What could the problem be?
Registered but harmless
Received 1,149 Likes
1) Check to make sure the dealer tech installed the inserts correctly-- sounds like the insert may not be secured properly at the top end of the blade.
2) Clean the windshield completely, preferably with glass polish or abrasive. There might be invisible remnants of some substance on the windshield (leaked oil, bird poop, etc.) which causes the blade to skip and squeak.
3) Tension problem with the blade/spring...see dealer again.
G/L.
G/L.
Clean the windshield with common rubbing alcohol to remove natures worst
Then install Bosch ICON wiper assemblies $20 each, All new blade with the springs built INSIDE- low profile- aero- even have a spoiler!
Only Grandma hugs you tighter
Fixes all vision issues
CheeseyPoofs McNut
10-11-2015 11:25 AM
