Notices
Squeaky scratchy belt/tensioner/pulley - Doesn't sound good
Old 03-15-2013, 11:13 AM
JJH
Registered Member
JJH's Avatar
So after going through the car wash today, my car started squeaking (which is nothing abnormal, it always does that if the belt gets a little wet or when it's real cold in the morning on cold start-ups), however, the squeakiness didn't go away. An hour passed and I drove to autozone to pick up some belt dressing. Upon opening the hood, this was worse that a typical dry squeaky belt. It almost sounds like sandpaper getting rubbed across cement. It worries me that either a pulley or tensioner is bad, especially if it's the alternator pulley because I will have to replace the whole thing.
Any ideas? I will upload a video clip with sound later.
Thanks Azine.
JJH is offline
Old 03-15-2013, 11:26 AM
Vegas Bum
JBONN's Avatar
Replace your belt and your tensioner if that is what you think it is, sounds like one of them is going if you are squeaky on cold starts...your sandpaper on concrete comment is throwing me off (maybe the tensioner bearing is worn out).
JBONN is offline
Old 03-15-2013, 11:39 AM
JJH
Registered Member
JJH's Avatar
Uploading video right now to Youtube...sandpaper on cement was a bad analogy.
JJH is offline
Old 03-15-2013, 11:58 AM
JJH
Registered Member
JJH's Avatar
JJH is offline
Old 03-15-2013, 11:35 PM
Registered Member
hrod26's Avatar
Sounds like a failed bearing to me...could be a pulley on the serpentine belt system or the timing belt itself. First remove the serpentine belt and start the car. See if the noise goes away. If it doesn't go away, it's likely a failed tensioner/pulley in your TB system. If the noise does go away, listen with a long screwdriver (or other steel object) and try to diagnose which pulley is louder than the others (stethoscope method).
hrod26 is offline
JJH (03-16-2013)
Old 03-16-2013, 08:43 AM
JJH
Registered Member
JJH's Avatar
The timing belt was changed less than 40k miles ago, do you really think that it's likely that a bearing would fail on me this soon?
JJH is offline
Old 03-16-2013, 09:53 AM
JJH
Registered Member
JJH's Avatar
Morning everyone
I've got some oddities to share with you guys about my squeaky scratch noise.
-I took the serpentine belt completely off and the noise did go completely away, telling me that it's either the belt, a pulley, or the tensioner.-I took the serpentine belt completely off and the noise did go completely away, telling me that it's either the belt, a pulley, or the tensioner.
-When I spray belt dressing on the serpentine belt, the noise goes away completely for about 15 seconds. This leads me to believe that perhaps a pulley or the belt tensioner is not rotating at the same speed as the drive pulley (due to bad bearings or whatever) and when I spray the belt dressing on, it allows the belt to slide more easily over the pulley which eliminates the noise temporarily.
-When rotating all of the pulleys by hand, they felt fine. They didn't have any additional drag than I think they should have.
-There was one pulley on the bottom right (closest to the front passenger headlight on the very bottom) that had a very, very, very slight amount of play. Should I more closely investigate this?
Is there any surefire way of determining whether or not I do in fact have a bad auto tensioner? It rotates fine.
JJH is offline
Old 03-16-2013, 10:07 AM
Registered Member
wilzrsx's Avatar
What is this? is the A/C Compressor, this is the one you said had some play in it
And this? is the idler pulley
If you put the serpentine belt back on, turn on the A/C to see if the noise changes.
wilzrsx is offline
JJH (03-16-2013)
Old 03-16-2013, 10:29 AM
JJH
Registered Member
JJH's Avatar
Good idea, I wish I would have thought about this before taking the serpentine belt off.
JJH is offline
Old 03-19-2013, 06:25 PM
JJH
Registered Member
JJH's Avatar
Replacing the serpentine belt eliminated the sound completely. The only thing that I can conclude is that somehow the old belt got stretched out.
JJH is offline
AndrewS
18
02-09-2019 05:24 AM
tonio
02-05-2019 05:43 PM
Iain MacLeod
Second Generation RDX (2013-2018)
09-17-2015 01:01 PM
PortlandRL
09-14-2015 12:01 PM
NSolace
09-03-2015 08:02 PM
Quick Reply: Squeaky scratchy belt/tensioner/pulley - Doesn't sound good
