Slave Cylinder??????
hey guys, i was wondering when changing the slave cylinder on a 6 speed, is it neccasary to change the master cylinder as well? Some feedback from those that have done this would be very helpfull...Thanks
Well, its not my car but its my girls car. She has a 05 TL 6 speed. I was doing a oil change today and noticed that the slave cylinder was leaking and also it was very lose, like i can push and pull very easily and lots of play...I wanna change it but i just wanted to know if you have to chnage the master as well
bluetl04 (07-30-2012)
Yes you will have to bleed it, when you remove the line from the old s. cyl. you get air in the line. After you get the new one installed fill the clutch m. cyl. & open the bleeder on the new s. cyl. & just wait til the fluid starts dripping out (takes a few minutes) that lets the fluid push most of the air out of the system. Then do a normal pump & bleed. Do a search on "bleed slave cylinder".
bluetl04 (07-31-2012)
Thanks again man.....
SidhuSaaB
05-30-2020 12:40 AM
mlody
12-04-2019 02:11 PM
joflewbyu2
10-08-2015 11:16 AM
