Side Engine Mount Bracket Part Numbers
Does anyone know the part numbers for the side engine mount brackets?
I know that top bracket that bolts to the mount is: 50620-SDB-A00
The lower bracket covers the water pump and the upper bracket bolts into it. I think one of the bolts has stripped out the bracket and I'll need to replace it eventually. I can't find its part number anywhere. Anyone know?
then the above link will do nicely or you can just look here
http://www.acuraoemparts.com/delray/...All&vinsrch=no
I looked at this page and part 5 (50620-SDB-A00) is one that I need, but I also need the part it bolts into, which is located between the top covers of the timing belt and over the water pump. I don't see it in this image - or am I just blind...
#56 30 and the other part right of it
darksky
09-05-2015 03:11 AM
