Shifting problem
Old 07-10-2011 | 03:51 PM
cbass's Avatar
Shifting problem
This morning I started having problems switching out of park, or going from drive to reverse and then to park. I'm pretty sure it has something to do with the brakes because if i pump the brakes a few times it lets unlocks and lets me switch gears. Has anyone had this problem? its an automatic 04.
i hope its not something big..
Old 07-10-2011 | 03:56 PM
ez12a's Avatar
the overexplainer
lock out switch? I dont know if the brake light pedal switch does that function (6mt here).
Old 07-10-2011 | 03:59 PM
friesm2000's Avatar
B A N N E D
the shifter interlock is having intermittent issues
more then likely either a bad brake switch (on the brake pedal),
or the interlock solenoid on the shifter itself, which i think might be more of a possibility because you say you are having issues shifting into even reverse (i think... or is it when going to park from reverse), but either way it should not even need the interlock to work to shift into park, such as when the car is already off (shop environment), you normally can just slid the shifter straight into park without an hassle; SO my next thing would be is have you spilled something (sticky possibly) onto the center console especially around the shifter recently?
Old 07-10-2011 | 04:08 PM
cbass's Avatar
im only having problems when i have to push the brakes to shift gears, which is moving from park, or going from drive to park.
Old 07-10-2011 | 04:11 PM
friesm2000's Avatar
B A N N E D
as said the interlock does not really need to work 100% going INTO park (it should just push the lock piece out of the way), but coming out it does, part of the reason why is ask if you might have spilled something recently, and the lock possibly sticking or something
Old 07-10-2011 | 04:32 PM
cbass's Avatar
fixed. for now at least. i just unplugged the brake switch and plugged it back in and it fixed the problem.
THANKS!
Old 08-01-2011 | 05:05 PM
cbass's Avatar
started sticking again
i took apart as much as i can and i see someone spilled some liquids and found some sticky stuff. i tried taking apart and cleaning as much as i can and got stuck here.. is there any easy way to get beyond this point to clean inside?
udelslayer
1G RDX Problems & Fixes
05-06-2016 12:27 PM
JDMVP
1G TL (1996-1998)
09-17-2015 06:14 PM
Mike Bertram
09-10-2015 09:27 AM
HeloDown
09-08-2015 06:51 PM
jfman55
09-05-2015 02:55 PM
Quick Reply: Shifting problem
