Searching/bouncing Idle?
Only happens when the car is started after sitting over night. basically the idle searches from 750rpms-1200rpms until the car is warmed up. at first i thought it was a cool little feature to warm up the engine faster, but realized how stupid that sounded.
so anyone else have this? i don't feel like dragging my ass to the dealer, sicne the most likey won't let the car sit there overnight.
Originally Posted by simonsez
mine just stays at 1200RPM then drops to around 1000RPM couple of mins. of warming up
yup, thats how it's supposed to do it
if this was an older honda i would replace the Idle Air Control Valve, but i'm pretty the TL doesn't have one
the car has been at the dealer for 3 days now, they can' figure out the issue, they also won't take ay advice from me as what to look at. So i'm hoping the call the honda tech's who will come down to the dealership to help them out.
Originally Posted by acura911
what dealership do you take it to in nyc?
until i get the car back i do not want to give out the dealerships name. It's not nice to do that to dealership especially when hey could have people from there reading this site
ok that's cool.just let me know when you get your car back.
any one else have any ideas?
after reading the service manuali'm thinking it's one of 5 parts that could be bad.
it could be the throttle body, ECU, APP sensor, Throttle Actuator control Module, and the Throttle Actuator control Module relay
when i first start mine up, it ranges from 750 to 1,200 - like yours, but no "bouncing." It starts @ high RPM and goes back down to 750 after a few mins. The other day it was about -2 and that happened.
mine actually jump between the rpms until the car is warmed up
yeah the bouncing would probably weird me out. I've only had my car serviced once here in the city, mostly b/c I dont trust mechanics in NY... (my best friend is a mechanic - but he's not Acura - bummer) I service it when I go back to FL, and occasionally I'll service it b4 the long drive there to make sure everything is everything. Hope your car comes through though.
Originally Posted by csmeance
do you have the air or something else running? I noticed on my loaner Tl that when the heat was on, the idle would bounce slighly, from 800 to 1100.
Could have an upper or lower intake manifold gasket leaking and causing a vacuum leak untill it gets warm. I have never seen this on a Honda product but have seen this issue on Ford and mazda products.
Also does the Tl use a thermal idle control valve? I know in the past some Honda's used both an Idle air control valve and a thermal control valve.
I'm guessing vacuum leak, too.
If you get the car back without it fixed, then try pinching the vacuum hoses shut one at a time with a pair of pliers.
Don't forget the brake vacuum booster line.
those were the first things that were tried since those are the obvious ones. So nope, it's not a vacuum leak
Might sound stupid, but do you think it could be a bid clip or pipe orsomething of the nature that is cauing the leak? I got this because those hoses might heat up a little and become tigher around the cilips. just my crazy, random
that would be possible if this happened after the car warmed up, but only does it on a cold start
just got off the phone with Acura as i was typing this out, seems as if one of the O2 sensors died, but wasn't causing a CEL
4 months ago i took the car in for service because of a CEL which was for the rear primary O2 sensor, but by the time i got to the dealer the CEL cleared, and they told me nothing was there. Guess they should have listened the first time i went there
DerrickW
11-15-2015 06:52 PM
