RPM's rev when step on clutch in reverse?
Old Dec 26, 2012 | 04:33 PM
jnnyjuice's Avatar
Hey guys, not sure if im losing my mind or not but has this happened to anyone else? On my type s, whenever the car is in reverse and i step on the clutch, the rpms rev up a bit as if my foot is on the gas, but it isnt. Any ideas on why this is happening?
Old Jan 9, 2013 | 12:11 PM
jnnyjuice's Avatar
anyone?
Old Jan 9, 2013 | 12:14 PM
could be the rev hang.
it does it in forward gears as well.
Old Jan 10, 2013 | 04:21 AM
jnnyjuice's Avatar
You know what, you are right, it does ... How do I go about fixing this? Thanks fr your help man
Old Jan 10, 2013 | 06:53 AM
Sutitan's Avatar
Does it do this after has fully warmed up?
the TL's rev a bit higher when cold to warm up the cats so they can be more effective at removing pollutants. Something to do with they ULEV status.
My engine will rev just above 1k when cold and drop down to about 800 when warm. Im not sure if those are exactly the numbers, but there is definitely a noticeable difference.
Old Jan 10, 2013 | 06:55 AM
its a "feature"
you cant "fix" it.
Adapt your driving style to match the car.
Old Jan 11, 2013 | 04:03 AM
jnnyjuice's Avatar
Yes , the car can b warm and it still does it
Old Jan 11, 2013 | 06:30 AM
^thats because its a feature of the car....
Old Jan 11, 2013 | 10:40 AM
ez12a's Avatar
the overexplainer
let off the gas a split second before you disengage the clutch and you wont have the problem.
Old Jan 11, 2013 | 10:55 AM
I hate cars's Avatar
I despise the rev hang of any car. It makes it easier to drive smoothly for the clueless and makes it harder on the people that do know what they're doing.
Old Jan 12, 2013 | 04:13 PM
jnnyjuice's Avatar
Ok, can anyone explain the point of the rev hang? Why has no other car that I have owned had this (or at least it wasn't as noticeable as this) and I have owned several other acuras
Old Jan 12, 2013 | 04:14 PM
jnnyjuice's Avatar
I have tried that and it still seems to do it. Always sounds like I'm riding the shit out of the clutch
Old Jan 13, 2013 | 02:12 AM
ez12a's Avatar
the overexplainer
it's a byproduct of throttle by wire (your other acuras may have been cable actuated). If it's intentional the only reason i can think of is to make shifting slower/easier for the casual driver.
the point of throttle by wire is for better economy/emissions since the computer in the end is controlling it.
I doubt there's much clutch wear because of it as long as you engage the clutch with minimal slip. A member has gone over 200k with the original clutch.
tsx_boy
Dec 13, 2019 08:33 PM
knight rider
Mar 4, 2016 08:59 AM
DerrickW
Nov 15, 2015 05:52 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
Joe Avesyan
Sep 29, 2015 03:57 PM
