RPM's jumping
Old Mar 8, 2007 | 08:42 AM
thor32766's Avatar
RPM's jumping
I have an 04 tl with 38.000 miles on it. When I am cruising about 50 miles an hour the rpms will jump up and down from about 1500 to 2000 back and forth. Any ideas? I have read somewhat that the 04's had a transmisson recall. Any links to the recall. thanks for your help
Old Mar 8, 2007 | 12:32 PM
01tl4tl's Avatar
register your car at www.acura.com ownership experience to learn about any warranty.
The earlier 00-03s had the prob thought to be fixed with trans.
Then take your ride to the dealer or parts store to pull codes
Need them to help diagnois, but does not sound trans related
Does the rpm INDICATE is moving around- or actually do it?
Old Mar 8, 2007 | 01:24 PM
thor32766's Avatar
yeah the rpm guage jumps up and down.
Old Mar 8, 2007 | 01:40 PM
01tl4tl's Avatar
So only the guage is moving the engine speed does not change- correct?
Go to auto parts store and ask them to pull the codes- its free
Then we can narrow down past things like alternator, ignition switch, battery or battery cables and connections. A good look around is the first thing
Old Mar 8, 2007 | 04:48 PM
thor32766's Avatar
no you can hear the motor jumping with it. really wierd
Old Mar 8, 2007 | 06:37 PM
Will Y.'s Avatar
Registered but harmless
It sounds like your transmission is hunting for the proper gear, if you are going very slightly uphill trying to maintain a steady 50 mph and your transmission is trying to decide between 4th and 5th.
Does this hunting happen under any other conditions or speeds? If not, the car is fine. I'm not aware of any recall for the '04s for any transmission issues; you can check the 3G Garage thread for info on TSBs and recalls.
Old Mar 8, 2007 | 07:58 PM
shayan's Avatar
WOW, I have the same problem but mine is an 2005. I was gonna go to the dealer and ask them if that is bad or not, but never did because it never happened at any other speed
Old Mar 9, 2007 | 11:53 AM
thor32766's Avatar
so shayan yours does that just crusing and it starts jump up and down. i guess since I am under warranty for a liitle longer I will take it in anyways.
Old Mar 10, 2007 | 06:49 PM
shayan's Avatar
^ Please reply back with what they come up with and what they fix if there is a problem
copmagnet82
4G TL Problems & Fixes
Jun 29, 2016 08:09 AM
DerrickW
Nov 15, 2015 05:52 PM
Houston
Oct 8, 2015 01:27 AM
wubly
Oct 6, 2015 02:45 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
