AcuraZine - Acura Enthusiast Community (https://acurazine.com/forums/)
-   3G TL Problems & Fixes (https://acurazine.com/forums/3g-tl-problems-fixes-114/)
-   -   RL caliper conversion issue (https://acurazine.com/forums/3g-tl-problems-fixes-114/rl-caliper-conversion-issue-862158/)
UASICK Jul 4, 2012 10:24 PM
I was just wondering if anyone else who has the rl caliper conversion on their 3g is having any noise issues? After installing them, they were extremely loud but after breaking in a bit, the noise calmed down. But every time I make a right turn, it makes a pretty loud noise still. It is very inconsistent, sometimes it doesn't make any noise and other times it is the most embarrassing thing ever. The pads and the rotors look fine, which is why I believe it is the brackets causing some sort of vibration. The first time I took it off the brackets, I noticed some of the powder from the powder coat was rubbing off at a certain area where the caliper really didn't fit flushly with the bracket.
AnthraciteTypeS Jul 5, 2012 10:55 AM
Sounds like something somewhere is rubbing. I'd check the excess length on the adapter studs to make sure they're not nipping the barrel of your wheel- you may have to cut them down some
splew Jul 5, 2012 08:06 PM
I think fixed calipers in general make more nose than floating calipers. My OE Brembos make quite a bit of noise.
Like others said though, you might want to check that everything is in order just to be safe.
UASICK Jul 9, 2012 04:56 PM
Sorry for the late response, I forgot I posted this. So they were a little long, and trimmed it down but that noise has always been there since day one. I understand BBKs are loud, but these are the most ridiculously loud things ever. I mean you will hear me from 10 blocks away sometimes. My friend always laughs and tells me how far down he heard me whenever I see him.
Wolks War Jul 9, 2012 09:44 PM
Whats your pads brand???
Also, I would look at the hose to be sure she is not twisted
UASICK Jul 12, 2012 09:55 AM
I have EBC Redstuff. The rotors are racing brake i believe. I am going to play with it this weekend, so hopefully it will be resolved. It is so bad I think about selling the brakes
Wolks War Jul 12, 2012 07:52 PM
Wierd.....:annoyed: EBC redstuff should be really quite, thats what I have for street use.
Before selling them, have you installed de shims between pads and pistons, 'cause my EBC didn't came with them, I used my OEM's. They are used to always keep the pads straight against the rotors.
You can aslo buy the anti squeal paste, they do a great job when I put the Hack HP plus who are squealling like hell when not heated up
+ be sure everything is well greased, no rust.
hope it helps, good look :wish:
ArthurL Aug 13, 2012 10:16 AM
Hm.. that's weird. I just installed my calipers this weekend and didn't have a problem at all with noise. I have EBC RedStuff pads and BrakeMotive rotors.
I would try removing the rotors, pads and calipers and installing them again. Also did you rebuild the calipers before you put them on? It's fairly cheap.. I bought the rebuild kits from AutoZone for about $18.
And btw did you go through the bedding process for the pads?
KidChenz89 Aug 18, 2012 12:24 AM
what size rotors are you running? either that or the brackets were installed incorrectly?
© 2026 MH Sub I, LLC dba Internet Brands
