Right side HID light has gone bad
It looks like I have to replace the bulb. It has gone bad, I noticed it when I saw the reflection of my car in the back of another car. I noticed it and turned the lights off, then turned it back on and the light came on. The next day, same thing however, the light slowly dimmed and thats it. Now it does not turn on (not even on high beam)
Hopefully it is just the bulb. I should get both of them replaced correct? Does anyone recommend a good set? Also, I am not too mechanical but not scared to try and replace it myself. Is it easy?
Loving my 08 TLS!
Yes, you just need to replace the hid bulbs. I think it is best to change both at once to match the color. Check the vendor sales section in the black market. They do sell hid bulbs for a good price.
i got mine from our vendor excelerate. he has kaixen replacement bulbs for around 100 shipped. stock output is 4300 k. go with 5k if youre looking for something close to stock. check out the sponsored sales and groupbuy section
You should see the difference between a stock hid and a 6000K before buying , it's not like higher the better. Go search and you may be able to find some pictures, although picture is not very good at showing this kind of stuff...
Being an Acha Bacha in
As you go up in Kelvin rating, you lose lumens. Simple as that. Lumens is defined as the amount of useable light for the driver on the road. So going to 6000K from stock 4300K you will lose light and yes it is noticeable. However its not that bad, and the benefit is the aesthetics. Kind of like doing bigger rims, your ride comfort is sacrificed but your aesthetics are improved.
As far as the Kaixens are concerned, I've seen some sky high positive reviews to piss poor reviews on this site about them. Search for Teknokings reviews .. I think he noticed some light angling problem on them.
My personal opinion, I think HID manufacturers just over hype the technology and make it seem like it should cost 3x as much as it should. Just buy one with a good warranty and from a good vendor and thas about it imo. Everything else is just so minor none of us will notice it.
And to those that are wondering if I own Kaixens, the answer is no. I'm done with the days of spending hundreds on name brand HID's..I use to be a Philips only guy but I've come to my own realizations about all HID's. However, I also at one point, felt more comfortable buying the more expensive stuff, so I can't blame anyone that feels that way. We are programmed to think that things that cost more, must be better.
Damn, I think it might be an electrical problem. Yesterday as I am driving home, I flipped the switch and both lights came on. I turned them back off and turned it back on and only the left came on, not the right. I tried a few times and the right came back on and when I turned it off and turned it back on only the left... Can it still be the bulb or most likely electrical?
I'll do it this weekend. Most likely it will take me 2hrs for a simple job like this and my skills
im a noob at installs too, but i had a friend help me install new bulbs and we knocked it out in about half hour . check the DIY section, im sure theres a step by step guide for you 3G guys
practicing nihilist
it's me, Alan Rickman.
I had a light go pink; in addition to needing new bulbs [since one was now bad], my regulator/ignitor were both shot.
You have to be EXTREMELY careful when dealing with the electronics, there's something like 25,000 volts that are passed to the bulb. Make sure they are disconnected before you touch anything, make sure everything has had ample time to cool off as well.
My light would come on and function normally for a short time, then it would start flickering and turning pink. The regulator was not doing its job thus causing the issue.
So you could just have a bad bulb, or you could have a bad bulb and a bad ignitor/ballast. I can pull up the paperwork but it was roughly $600 in parts (<3 my warranty)
sockr1
10-01-2015 01:31 AM
