AcuraZine - Acura Enthusiast Community (https://acurazine.com/forums/)
-   3G TL Problems & Fixes (https://acurazine.com/forums/3g-tl-problems-fixes-114/)
-   -   Replace steering rack? (https://acurazine.com/forums/3g-tl-problems-fixes-114/replace-steering-rack-1003151/)
robster80 May 28, 2023 05:37 PM
https://cimg8.ibsrv.net/gimg/acurazi...ba3cb5b060.png
is this just grease from the torn boot or is this a leaky seal? If leaky seal only option is replace steering rack?
joe.abp May 31, 2023 05:46 PM
That boot is just meant to be a dust cover, oil dripping out means the seals are blown. So yes, replace or rebuild. Also if you're steering rack seals are shot your power steering pump seals are likely toast as well. Rebuiling the pump with new seals is easy to DIY.
robster80 Jun 2, 2023 03:06 PM
ive not noticed any dripping. Ive had two mechanics say “naw thats just grease u just need a new boot”, then on acura groups seeing the pic its suggested to get a new rack. So definitely get the rack? Is it best to just find and purchase a used rack or rebuild this one?
Pair of TLs Jun 2, 2023 08:26 PM
+1
How's your power steering fluid level?
Also, find better mechanics.
joe.abp Jun 2, 2023 11:04 PM
I can only assume your "mechanics" are referring to the CV boots that contain grease which is an entirely different part. If you can find a reputable mechanic that can rebuild with OEM seals it's pricier but will last the longest. If you go with the used route, confirm it atleast has low mileage. 20-year old seals over 200K can be a toss up.
Also look up above the boot to see if theres any engine oil dripping from above. If your PS fluid is near the top mark it likely your boot was just worn from the dripping engine oil.
robster80 Jun 4, 2023 04:54 PM
i do have oil leak trying to pinpoint exactly where. Ill look to confirm if its dripping onto that area as well but i know its leaking in the front of the car. Local shop says i need to replace valve cover gaskets and to replace spool assembly, oil pressure switch,pcv valve also.
© 2026 MH Sub I, LLC dba Internet Brands
