Removing transmission from motor - 05 5AT
Old 11-23-2016, 06:22 PM
BreezyTL's Avatar
Received 1,041 Likes on 773 Posts
Hey guys I need some help here. I am trying to remove the transmission from the motor so I can put the motor on my engine stand to get the cherry picker out of the garage. I have all the main bell housing bolts out and the 2 - 14mm bolts on the bottom. My question is, am I missing anything else or is that really it to separate the two? I have the bell housing about 1 inch off the block but it won't get any further and separate. Let me know if there is any trick to separate them or if you can point me to a DIY. I haven't found anything while searching.
I just need to get this done so I can park some cars in the garage finally....
Any help appreciated.
Old 11-29-2016, 08:17 AM
BreezyTL's Avatar
Anyone have a diagram of the flexplate bolts? That seems to be where I am hung up...
Old 11-29-2016, 06:09 PM
srg818's Avatar
Hope it helps:
Do you have access to the service manual? I took these from page 14-215.
Old 11-30-2016, 01:29 AM
Majofo's Avatar
Received 11,843 Likes on 8,574 Posts
Brah.. Y U NO PULL IT OUT FIRST?????
It's a bitch and you need room..
If you already got it taken care of, disregard..
Old 11-30-2016, 08:33 AM
BreezyTL's Avatar
Thanks guys. Got her taken care of last night. Harder to do with it sitting on blocks of wood. I guess I wasn't level enough to slide the converter off the shaft.
Old 11-30-2016, 09:18 AM
Majofo's Avatar
Prime for the picking..
What are your plans Breezy?
Old 11-30-2016, 09:52 AM
BreezyTL's Avatar
Well I have my TL-S and really no need for this motor. I plan on parting it out or try to sell as a whole. No luck as a whole so far, I think the 196k Miles turns people away.
AXLEHOUSE
10-14-2019 01:04 PM
Ahmed Nomaw
07-20-2017 04:06 PM
Kolomango
3G MDX (2014-2020)
07-15-2016 08:55 PM
mjgreencs
06-20-2016 04:19 PM
qwxilvr
5G TLX Problems & Fixes
05-07-2016 02:35 AM
Quick Reply: Removing transmission from motor - 05 5AT
