Rear view mirror
Old Mar 22, 2010 | 04:02 PM
mackymacalincag's Avatar
Rear view mirror
In regards to my 2004 Acura TL:
Ever since I bought my car (used) the rear view mirror has been falling off, especially on a bumpy road. Any advice on how to tighten it? It's so annoying. I don't see the point in buying a new one because the dimming still works, IT JUST FALLS OFF. If anyone has any thoughts on this matter let's hear it.
Old Mar 22, 2010 | 04:33 PM
badteddy's Avatar
i had that problem but i had a mechanic do it for me.. i didnt really get a good look at it. it took him a while becuase he didnt want to break it. but you'll need a really good grip and a pair of good pliers. you have to squeeze a clip to make sure its gripping the mirror.
Old Mar 22, 2010 | 05:26 PM
nfnsquared's Avatar
There's a TSB for this problem. Your dealer should cover it even if your past warranty:
Use the sticky link at the top of the "Problems" forum to find more TSBs and other useful info.
The 3G garage also has tons of useful info. There is a sticky for the 3G garage in the main forum.
Old Mar 22, 2010 | 10:42 PM
Foxman09's Avatar
Re: Rear view mirror
There is special adhesive required to stick to the glass and the rear view mirrors. It comes in a kit with instructions. The main thing when reattaching the mirror is make sure the glass and the mirror mount are very clean. You can get it at a Auto-parts store, I have seen the kits at Wall-mart. I glued mine on once and it's been on for years, must of got the good stuff.
Here is a site that shows the kit:
http://www.amazon.com/Loctite-Rearvi.../dp/B000VNAIQ2
Old Mar 22, 2010 | 10:48 PM
nfnsquared's Avatar
Oops, sorry, pasted the wrong link in my post above. The TSB is:
http://www.in.honda.com/Rjanisis/pubs/SB/B06-012.PDF
Old Mar 23, 2010 | 12:47 PM
DimwitRj's Avatar
that ONE RED tl
I read that TSB, bought a new clip, installed and still had the same problem. Took the mirror apart again and bent the tabs on the clip a little with some pliers and problem solved.
Old Jul 8, 2010 | 12:41 AM
racura's Avatar
3rd Gear
I have the two plastic covers off, but cant seem to find where the screw is. Could anyone help? Mine shakes so bad I get dizzy changing lanes.
Dec 7, 2020 05:39 PM
BoricuaTL
Apr 8, 2016 01:08 PM
Rocktman1
Oct 31, 2015 02:33 PM
Sep 17, 2015 10:16 AM
dre707
Sep 8, 2015 08:32 PM
