Rattle by seat memory buttons
I have a very annoying rattle by the seat memory buttons on the driver side door as well on the passanger side in the same place. Has anyone else had this problem? If so what did you do to fix it? If I put pressure on the door (around the seat memory buttons) it goes away a little but but is still there.
Thanks,
Mike
Thanks,
Mike
Registered but harmless
Received 1,149 Likes
Check the outside mirror housing where it attaches to the door-- there was a TSB for squeaking/rattling. Take a look at the rattle threads in the 3G Garage if the mirror housing is the problem.
Also, you can pull the door panel and make sure the memory seat unit is fully screwed down from behind. I believe there are video DIYs in the 3G Garage for removing the door panels. If not, search for "KP Window" by user "FAST4DR" for details and pics on removing the drivers door panel.
