Radiator fan is running after I turn off the car
So I had to replace my battery yesterday because it died. It died because the radiator fan is running for up to 20 minutes after the
engine is turned off. I know that''s common on a warm day, but it''s been happening on short drives in 50 degree weather here in Florida. Possible symptoms are: 1. Thermostat is busted. 2. Fan temperature sensor is busted. 3. Low coolant in radiator. Anything else it could be? |
Weird. I didn't even know there was a fan temperature sensor. It seems like that would be the culprit. The thermostat is going to stay open until the coolant cools off anyway, so I don't see that being the problem. And low coolant in the radiator would be easy enough to check. How about the coolant temp sensor? Do you see high temps when driving?
Long trips, yes I do. The needle gets to about 3-4 ticks below the hottest (or highest) mark. On a normal trip to work, which is about 11 minutes on the highway, it doesn't get that hot, especially now.
On 2007-2008 TLs, the car has two Engine Coolant Temperature (ECT) sensors: one underneath the radiator and one underneath the throttle body. I will check the coolant level when the engine cools down.
me thinks fan relay could be stuck in the on position
Hmmmm. I'd say there's definitely something going on with your cooling system. You might try doing a full cooling system service. Flush, clean and refill. Of course, check the coolant level first to rule that out. Worst case scenario, the water pump could be going out. Or the thermostat.
I'm too lazy to look it up in the manual :tongue: (well in reality, just got some actual work to do but find the proper relay, remove it while it's running to see if it goes out. It could very well be a sensor to but I'm thinking bottom up rather than top down. I.e. Fan running, what triggers fan to turn on from an electrical perspective: a relay. The sensor I would check next and then the water pump and coolant and all that jazz.
Originally Posted by losiglow
(Post 16133935)
When the fan is running, and I take out the 30A fuse, the fan turns off. I will check the relay next. First I want to check the coolant level.
(Post 16133931)
Ahh in that case, that sounds like the relay is ruled out as well. Unless it's just intermittent :scratch:
of course if the fuse is pulled the fan will stop running! :tomato: |
Coolant level is fine. It's between the min and max levels on the overflow container.
(Post 16134098)
I did check it in the radiator, and I could see remnants of coolant at the top, just below the radiator cap (when I take it off). In addition, the upper and lower radiator hoses are both hot, which tells me that the radiator is working that the thermostat is opening and allowing coolant to cycle through the radiator.
In an interesting observation that I had today was that when I was driving here around town for about 30 minutes in ~50 degree weather, I never heard the radiator fan come on when I was driving. However, as soon as I parked and turned the engine off at home, it came on. Weird. |
I don't think the fan is coming on when I drive.
Replace the radiator.
The radiator fans are only coming on when the engine is off.
(Post 16138921)
When the car is running the water pump is moving faster so the radiator is more efficient to keep the engine cool. However, the fans are still running more that it should, you just haven't notice it yet. In a perfect storm situation you car will get warm or even over heat. If not now but certainly in the near future. You can confirm by removing the radiator cap when the car is cold and see if you can observe any coolant circulating in the radiator once the engine is hot. The engine is hot once the fan cycles on. In a good radiator you will see coolant flowing from one side to the other when the thermostat opens and the flow stop when it closes. |
Originally Posted by 01acls
(Post 16138934)
That's correct. The reason is because the tubes are closed up in the radiator so not enough circulation in the radiator to cool off the coolant. That's why the long run time of the fans.
I would suspect the fan switch gone bad, it's ability to shut off at 180 deg is now 160 deg giving it 10-20 minutes more time to shut off.
Cheers, Jim |
(Post 16138990)
Yes, but I see the temperature gauge go way past normal when the car is stopped at a long light, but the radiator fan does not come on when the car is on, even when we are stopped. I have felt the top and bottom radiator fan hoses, and they are both very warm, which tells me the radiator is working to get coolant to where it should.
Note, if you do nothing you will over heat and blow the head gasket or blow the water pump seal and the head gasket. Faulty senders tend to be on or off not variable temps. |
Fan not working
First hot wire fan to see if working then test the thermal switch for the fan today!
i would not think relays are involved with this control process. |
The fan is working perfectly fine Jim. It, however, only comes on when the car is turned off, which drained my old car battery quickly.
So I took my car in to have the overheating problem diagnosed. They said that there is a very small leak on top of the radiator, but I didn't notice because it wasn't leaking that much and the leak was drying up before it hit the ground. In addition, the coolant level was between the min and max. So here is what I've determined that could be the problem:
1. 2. 3. 4. 5. 6. Thermostat. I have not ruled this out, but doesn't the thermostat fail in the open position, allowing the coolant to flow through the radiator? 7. Engine Coolant Temperature (ECT) sensors. The 2007-2008 has two sensors (2006 and earlier have only one ECT sensor). Sensor 1 is under the throttle body on the coolant passage casting, and sensor 2 is on the lower left side of the radiator. I suspect it could be the ECTs. What are your thoughts? |
My question is why are there two ECT sensors on the 2007-2008 TLs? Is it because of redundancy or does one sensor operate the fan at one speed and the other sensor turns the fan on to a much higher fan speed?
I got a shop manual from Rockauto for my 2010 TSX it has more than I want for solving problems if you could find a "shop manual" for yours I think this may help?
Yes temperature sensors that regulate fans can go bad so replace any or all of them because you do not know the impedance values with temperature standard operating requirements. You said they operate with relays this means ECU has a hold on the relays for shut time after engine is off, doubt program could be the problem? Most all cars today run the same way so a schematic fan diagram would be helpful. What year and type TL you own? |
Talk about temp sensors I had an early 80's Chevy Cavalier that had 5 or 6 temp sensors around the goose neck to control many different feed back sensors just crazy stuff
I have a 2008 TL Type S.
I found a relatived issue read through
https://acurazine.com/forums/1g-tl-p...ng-fan-764684/ His last words! it was a bad temperature coolant sensor/switch. |
I'm going to piece-meal it. I will buy a Engine Coolant Temperature (ECT) sensor, replace the sensor that is below the throttle body, and see if that fixes the problem.
(Post 16142844)
To check a relay apply power to the pins that have continuity and the open pins will then have continuity. Defective Radiator... You're 10 ways wrong by not changing this first. A leak will allow air into the cooling system. ECT may not read correctly due to air in the system, ETC is reading the air pocket. Low coolant pressure lowers boiling point of coolant, car runs hotter than normal, ETC reading is not correct. Coolant will not siphon from over flow tank, air has least resistance so air enters coolant system. Coolant lost...etc. |
All we can do is try one step at a time while learning all the facets entailed with the cooling system
where sensors & relays are located and the ecu pinouts for this operation. Radiators are $48 bucks on ebay. We should know how many miles are on this tl. |
Miles are irrelevant and don't help solve the problem.
Just placed an order for a new Spectra radiator on Rock Auto.
Miles can gave a status of run time on all assaulted parts with a car having 200k or 400k will show a difference and how well one takes care of it.
You stated a small leak from rad so that should have been the first move to make, let us know what happens. |
I replaced the radiator fan and the overheating issues went away.
It was the fan after all even after you had check it earlier, how could that be.
Keep the old one and disassemble it and clean commutator then have a spare. |
(Post 16146845)
Miss out of 31,386 posts it looks like you still haven't learned anything, keep on typing you'll get there?
:chuckle:
