Question
Question
I just replaced the radiator in my wifes 2007 acura TL, the Transmission cooling line rusted from the bottom of the radiator. I somehow pulled a single wire from the cooling fan harness, and can not find where it goes. It is on the passenger side about mid way down the shroud, ands it is just a single wire coming out of the harness, spade connector still intact. The A/C now will not work, ant advice would be greatly appreciated...
Welcome to the forum.
The forum where you originally posted, The AcuraZine User Help, Support & Suggestions Area , is meant for problems, comments, and suggestions for the website itself, so I moved your thread to the car specific forum applicable to your vehicle.
If it's about 6" long, there is a clip about 3/4 way down on pass. side of shroud and attaches to a tan wire that comes from the A/C compressor, at least I assume it goes to the compressor, hard to see from the top. The wire that it attaches to is probably hanging down directly under the compressor.
navtool.com
31
11-16-2015 08:30 PM
DerrickW
11-15-2015 05:52 PM
