Problem with HID/Ballast
Old Nov 11, 2014 | 09:06 PM
ACURATL210's Avatar
So recently I have been having problems my passenger side HID I had replaced it over the summer, but now it is flickering again. Anybody else have this problem?
Old Nov 12, 2014 | 03:07 AM
Solder's Avatar
What did you replace? Both the ballast and HID bulb?
Old Nov 12, 2014 | 01:30 PM
ACURATL210's Avatar
I just replaced the bulb itself, but I went to 6k. I don't think that was the problem though because i have read people here doing the same thing.
Old Nov 12, 2014 | 02:50 PM
TacoBello's Avatar
Sounds like it's your ballast starting to give out. The bulb itself wouldn't cause issues.
To be sure, you can try swapping your bulbs around and see if the problem persists. If it does, it's likely the ballast.
Old Nov 13, 2014 | 11:49 PM
ACURATL210's Avatar
Thanks guys I'll try to swap them and see if it makes a difference.
Old Nov 14, 2014 | 01:59 AM
YeuEmMaiMai's Avatar
swapping the bulbs will prolly be easier. if problem remains on same side, time for new ballasts or some more digging
Old Nov 19, 2014 | 08:01 PM
user 08723908028024's Avatar
I had the same issues with passenger side headlights. According to parts/description; the dealership replaced the following:
1. Control Unit - 3319-S2A-J01
2. Igniter, HID - 33129-S2A-J01
Now, my left side is doing the same issues. The bulb works; however, it goes out and flicks sometimes. If I need to get it on ebay - could you please help me out on what exactly do I need, for cheap?
Thank you kindly.
SidhuSaaB
May 30, 2020 12:40 AM
Fool
Mar 10, 2016 08:42 PM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
