Pre-cat Deletes, J-pipe and Test Pipe
First of all, I feel obligated to say this: that darn cat in the back is a PAIN IN THE ASS! It held up the entire project for an entire NIGHT...we had to come back the next day to undo the bolt that we thought was stripped
. Anyways, I have a question: can someone tell me HOW they know if they have a leak? Can you hear it inside the cabin, or only with the windows down? I can't decipher between the "hissing" noises - air rushing through the pipes (sounds like more free-flow air; almost like a cai) or leak. Also, I've yet to reset my ecu after the cel came on...but I wonder, does the cel coming on have anything to do with a "growling" noise upon initial start up? It's very faint, but it's definitely there...I thought maybe it could be the system running the regular systems check on start ups? ![Shrug](https://acurazine.com/forums/images/smilies/shrug.gif)
Thanks,
Eric
OH, and a BIG thank you to Richie Wong. The welding on the pre-cats cracked; needless to say, Richie sent me a brand new set of pre-cats. Thank you Richie!
![Rant](https://acurazine.com/forums/images/smilies/rant.gif)
Thanks,
Eric
HE>i
I haven't heard anything "hissing" other than the CAI after my install of the pre cats. But the deep growl on start up is definately there (which i like the sound of on my stock exhaust) and i think it is from the warm up effect of the factory cats and the extra fuel being sent through the cat deletes that causes the "growling" sound.
... no cels so far, so try resetting the ecu
you're kidding me! the only "hissing" noise you hear is from your cold air eh? dang...did you use sealant or anything of the sort? that could be the problem...I couldn't find any o2 safe gasket sealant, so we didn't use any. we just torqued everything to spec...
so there should be no sort of "cai"-esk sounds?
Permatex Ultra Copper sealant IS oxygen sensor safe and rated to 700 degrees.
I have used it for years on all exhaust sealing needs.
Used it on my precats/j-pipe/test pipe install and no problems or leaks at all.
just to confirm...you used the sealant and swiped it all over between the gasket and the actual pipes?
my cel won't seem to go away...despite the ecu reset? hm...what could it be? did you guys use the defoulers provided? we placed them on the lower o2 sensors...yay, nay?
HE>i
erick3, hit up Richie and see if the smaller defouler would solve the CEL problem. oh...and sorry to hear about the crack on the pre cats but glad to hear about the replacement. RV6 ftw!
It will seal and last until you remove it.
I race sprint cars and use it to seal the headers to an 820hp engine without a header gasket. The stuff works great.
MrHeeltoe
20
02-23-2023 01:54 PM
ExcelerateRep
10-14-2015 08:20 AM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
johnpancakes014
09-27-2015 12:58 PM
