Power window/Regulator
Anyone know how to reattach the cables to regulator?Passenger side front window fell down when cables let loose.
Motor still works fine & I am able to get the door panel off.
Sorry I don't, I just got my car back on Monday from the dealership where they replaced a faulty passenger front window regulator...it wasn't going all the way up on auto. $269. OUCH!
![ugh](https://acurazine.com/forums/images/smilies/ugh.gif)
it's 4:20
You need to replace the entire regulator, as the cables usually break causing the window to either fall in or not work at all. Your motor will unbolt from the old reg and bolt onto the new one.....Pretty easy to do, just be sure to unbolt the window from the regulator and remove the glass.
Acura604
20
08-05-2017 12:55 AM
