Power Steering Pump Replacement
Hi guys i have a 2007 Acura TL that needs to get its power steering pump replaced. Has anyone here ever got this replaced and how much did it cost. My steering wheel is hard as hell which I cant even turn it when its parked. When my car is started up in the morning has loud whine noise and goes away after its warmed up, so please anyone who can help me with this would be a big help.
Are you sure the rack hasn't failed also?
I think a failed rack can cause metallic bits to be pumped through pump, causing it to fail over time.
I would definitely examine some of the power steering fluid and do a complete flush before you replace any parts.
I did check the power steering fluid and there is not bits of matallic bits in the fluid. gatoferoz25 if your close by we can set up a time to meet up i live in central jersey.
The noise can be fixed by purchasing a brand new O-ring from the dealer.
https://acurazine.com/forums/3g-tl-problems-fixes-114/diy-105-power-steering-whine-fix-754586/
Resident Dingo
Yes, it can be bought at the dealer. Call them first to make sure they have it in stock before you go up there.
The dealer here (45 minutes from me) makes me pay for parts before they are ordered so I have to make the trip twice. Bastards.
ILLustriousUA6 (12-27-2011)
AZ Community Team
Received 7,771 Likes
https://acurazine.com/forums/showthread.php?t=754586
Usually.
Any of the seals going bad and letting air in could cause the issue. But the OP seems to have bigger issues than just the noise.
PS pump is easy to replace. There are Service Manual scans as noted below:
A-105: DIY: Power Steering Pump Rebuild
https://acurazine.com/forums/3g-tl-problems-fixes-114/diy-105-power-steering-pump-overhaul-pics-sm-scans-841134/ - With Pics and Service Manual Scans
https://acurazine.com/forums/showthread.php?t=754586 - PS Whine Fix (O-Ring Replacement)
mike from annapolis
05-07-2017 08:21 PM
asahrts
09-04-2015 05:55 PM
