Possible battery drain due to TPMS error
Does the never going away TPMS error result in a parasitic drain on my battery? It's the error where all 4 tire pressures show as blank.
The HFL has been disconnected years ago and I've only had this new battery for 8 months. Besides this TPMS error I also have the service required msg that hasn't been reset.
unlikely.. have you done a parasitic draw test to at least figure out which circuit it's coming from?
unlikely.. have you done a parasitic draw test to at least figure out which circuit it's coming from? https://www.youtube.com/watch?v=KF1g...ture=emb_title
definitely suspect and possible..
I did a draw test using my multi-meter and the culprit is the 'Interior Light' fuse (7.5 A). It's currently drawing .25 amps while the car is shut off.
What could be causing the issue as my interior lights all work fine? I've no issues with the: front overhead light, rear dome light and both front door panel lights.
The only thing I notice is that one of the two rear dome light bulbs seem dimmer than the other.
Mr. Eclectic
01-23-2017 03:47 PM
Blaze9
07-19-2016 03:47 PM
