Parking brake shoes need replacing
Old May 5, 2010 | 01:59 PM
princelybug's Avatar
LIST/RAMEN/WING MAHSTA 짱
Recently, I've noticed that on any incline or decline, my e-brake does not hold the car in place when I engage it. Even if I have the handle fully engaged to the lock point, my car slides. So I HAVE to leave the car in gear when I park, at all times. I want to fix this.
There was another member who replaced the e-brake pads, but I don't remember who it was, or which thread (I searched).
Can anyone provide a schematic, part # for the e-brake drum pads, and a DIY? Any/all of these would be appreciated.
TIA!
Old May 5, 2010 | 02:45 PM
nfnsquared's Avatar
Over 13,000 posts and you didn't look in the 3G Garage?
There are at least 10 different threads there for rear brakes/pads...
It may not be your pads. It may just be the cable that needs adjusting. This procedure is also in the Garage
avs007's Avatar
It's possible that you only need to have your parking brake cable adjusted. That happened on my other car... e-brake fully engaged, but not holding car... Adjusted parking brake cables, and now it works like it was brand new...
Old May 5, 2010 | 03:01 PM
Well, like I said, I did a search, but this is different than rear brakes/pads. I guess I could've looked more thoroughly.
I've actually done this a couple of times on my car. I'll try it again!
Old May 5, 2010 | 03:07 PM
Although I've done this a couple of times, don't our cars have "self-adjusting" parking brakes?
Old May 5, 2010 | 06:04 PM
nfnsquared's Avatar
My bad, those are for rear brakes/pads, not the e-brake. Here's the thread for e-brake/p-brake:
https://acurazine.com/forums/3g-tl-problems-fixes-114/e-brake-assembly-replacement-761003/
Sorry about that...
ATTENTION MODS:
There doesn't appear to be any thread in the 3G Garage that covers e-brake/p-brake. You might consider adding the above link to the Garage....
Old May 5, 2010 | 06:14 PM
https://acurazine.com/forums/showthread.php?t=761003
Sorry about that...
ATTENTION MODS:
No problem. Thanks for finding it!
Old May 5, 2010 | 07:01 PM
avs007's Avatar
I don't think so... But if you've done this a couple times already, maybe you really need shoes... I've never worn out my e-brake shoes, so I don't know...
Old May 5, 2010 | 07:17 PM
I'm pretty sure the e-brake is self-adjusting. Maybe someone else will chime in to confirm it.
I haven't went to adjust the brake yet, but after I do it, and it still isn't fixed, then I'll look into the pads.
Old May 5, 2010 | 07:31 PM
avs007's Avatar
I only heard of self-adjusting drums, when your actual rear brakes are drums, because they adjust when you press the brake while rolling backwards.
WIth that being said, I've only ever had to adjust the cables on cars that had rear discs with the cute little parking drums... Although I suppose the parking drum could auto-adjust the same way, but I never engage the ebrake while moving, so I don't know...
But even then, the adjustment, is the distance from shoes to drum... Your cables could still be stretched, and need to be adjusted to take up the slack...
Old May 5, 2010 | 07:44 PM
Hapa DC5's Avatar
אני עומד עם ישראל
Chill off those burn outs brah
Old May 5, 2010 | 07:49 PM
Right. That's why I said they should self-adjust, because the e-brake pads are like a drum setup.
Old May 6, 2010 | 09:12 AM
blkaspec's Avatar
Full of water...
i dont park on many hills but i got in the habit of using the ebrake on my last car when my auto trans went out...kinda paranoid and would rather wear that out instead of always making the trans hold me. not a big fan of it in this car though, never seems to do a great job...but, i have never done the adjustment. remember reading something about it in the service manual but didnt see anything about changing a pad, just adjusting it if it didnt hold hold after a certain number of "clicks".
Old May 6, 2010 | 09:20 AM
blkaspec's Avatar
Full of water...
Sorry about that...
ATTENTION MODS:
great link, good find!
Old May 6, 2010 | 12:09 PM
Majofo's Avatar
TIA!
They're shoes not pads sucka!
If they look good I would just adjust both sides. I hope you get it worked out , otherwise let the next guy deal with it..
Old May 6, 2010 | 12:42 PM
ccrun1800's Avatar
Same thing happened to me car rolling down inclines and such. I adjusted my e-brake cable and all was right after that.
Old May 6, 2010 | 01:32 PM
6spdtl-s's Avatar
Nismo TL yo!
replacing the ebrake assembly was such a b*tch, good luck. make sure to order all new hardware, especially the clips.
Old May 6, 2010 | 02:02 PM
I'm going to try and adjust the cable first. Hopefully this fixes it.
Old May 6, 2010 | 02:39 PM
nfnsquared's Avatar
There a thread started by mmade that has the scans for e-brake adjustment. It was the thread were he parked at a rest stop and his car rolled across the parking lot. I'll try to find it.
Here it is:
https://acurazine.com/forums/showpos...1&postcount=58
Old May 6, 2010 | 03:00 PM
Yup. I read that thread, and I've adjusted the parking brake cable a couple of times. Thanks!
Old May 17, 2010 | 10:58 AM
I adjusted my parking brake to where it'll only go 8 clicks, and my car still slides when I apply the e-brake on either a decline or incline. The Acura allotted number of clicks for the e-brake is between 6-10 clicks.
I think I'm stuck trying to replace the rear drum shoes.
Old May 17, 2010 | 11:26 AM
nfnsquared's Avatar
Did you try the major adjustment procedure? I find it hard to believe that parking brake shoes are worn to the point of needing replacement, but they could be. The only way to know for sure is to pull the drum and look at the shoes. If the shoes look OK, then doing the major adjustment, followed by the minor adjustment should solve your issue.
Old May 17, 2010 | 11:28 AM
Majofo's Avatar
PB's Asian.. he probably drove 1k miles before noticing his ebrake engaged. :troutslap
btw.. my advice stands from post #15
Old May 17, 2010 | 11:29 AM
I might have to do the major adjustment. You're right, it's probably almost impossible for the drum shoes to be worn down.
:sigh:
Old May 17, 2010 | 11:33 AM
I wish the diagram under #7 was larger. I have to do this on both sides, correct?
Old May 17, 2010 | 11:42 AM
Majofo's Avatar
orale carnale
Old May 17, 2010 | 11:45 AM
Nice! Now come on down and do it for me.
Old May 17, 2010 | 11:48 AM
Majofo's Avatar
I wish..
I need more car projects to keep me occupied.. The new house is not nearly as fun, this weekend I looked at drapes.. FML.
Although I did check out some tool chests.. I'm going to build a work bench as well
Old May 17, 2010 | 11:56 AM
Come on down. You're only about 300 miles away.
Old May 17, 2010 | 12:01 PM
Majofo's Avatar
I wish.. More like $300 away.. I live in Austin ~1500 miles from So Cal.
Old May 17, 2010 | 12:03 PM
I got it. Fly in!
Old May 17, 2010 | 12:04 PM
nfnsquared's Avatar
Decent pics of the sprocket in this thread:
https://acurazine.com/forums/3g-tl-2004-2008-93/d-094-diy-complete-brake-job-pics-624404/
Kind of hard to see the sprocket because it is behind the spring, but it's there. With a flashlight and a regular screw driver, you should be able to reach it.
Old May 17, 2010 | 12:06 PM
Majofo's Avatar
Let's meet halfway ... how about Vegas?! BIL has a house with a garage in Vegas so we're golden.
Old May 17, 2010 | 12:16 PM
https://acurazine.com/forums/showthread.php?t=624404
Are we free to use his place?
Old May 17, 2010 | 12:39 PM
Majofo's Avatar
yeah.. no problem, me actually getting consent to go back to Vegas is probably an issue, especially since we just came back a couple months ago. I'm no longer master and commander of this journey..
Old May 17, 2010 | 12:42 PM
nfnsquared's Avatar
Hehe, she's got it locked in her top dresser drawer, eh? Hate it when that happens
Old Jun 5, 2010 | 12:44 AM
Well, it turns out that I indeed did need new parking brake shoes.
Here's the back story: On about 3 separate occasions, I performed the "minor adjustment", without doing the "major adjustment" at all. As a result, what happened was that the parking brake shoes were pressed up against the rotor so much , that even when I disengaged the parking brake, it was still rubbing . This, after a while, wore out my parking brake shoes, and also put a nice glaze on the inside of the rear rotors as well. On to the pics:
Here's what the inside of the rear rotors looked like: (The other side was worse)
Here's a pic of the new brake shoes:
Here's a close-up of a new brake shoe: (Note the pad thickness, not very thick at all)
Here's some pics of the old shoes still on the hub:
Here's a comparison pic of the new shoe (top) and old shoe (bottom):
Here's a comparison pic of the old shoe (top) and new shoe (bottom):
Finally, a shot of the new brake shoes on the hub :
All in all, it was too much work just for the darn parking brake. But, I'm glad I have it functioning, now. I've learned my lesson...no more messing with the parking brake.
Old Jun 5, 2010 | 01:06 AM
KzooTL's Avatar
05' AT SSM
When you put the new brakes on did you have to adjust it at all?
Also where is the "Console boxlid" for the minor adjustment. In the cab under the armrest?
Old Jun 5, 2010 | 01:23 AM
Yes, you do have to adjust it. Look at letter "D" in post #27. This is the adjustment that is necessary. You'll also need to do the minor adjustment, and the way to get to that is to take the center console apart. You can get to the adjusting nut through the center storage console, but it's easier to adjust by taking apart the center console, pulling the center console storage unit back, taking out the cupholders, and adjusting from there.
