P0135 and P0155
Old Oct 11, 2012 | 10:51 AM
godfather18's Avatar
P0135 and P0155
My check engine light came on and I went to get the codes read and the codes are p0135 and P0155. I know its one of the oxygen sensors but dont which ones they are. Can someone lead me in the right direction.
Old Oct 11, 2012 | 11:41 AM
MonkeyTrucker's Avatar
Life Connoisseur
http://repairpal.com/OBD-II-Code-P0135-and-P0155
Old Oct 11, 2012 | 05:47 PM
Found the issue there was a blown fuse inside the cabin under the dash. I reset the ECU and the light went away. I wonder why a fuse would even blow that controls the sensors????
Old Oct 12, 2012 | 08:33 AM
Manimal_Forever's Avatar
Keep an eye out, rarely do fuses just blow for no reason.
Old May 6, 2013 | 03:08 PM
LS_GRINDSEASON's Avatar
4th Gear
Hello all,
Im having the same trouble with the sensors (0155-0135). which fuse did you blow? what else can i check? i have replaced the sensors already.
Old Sep 10, 2013 | 04:17 PM
helmsrj's Avatar
08 Type-S KBP
To fix this issue
Originally Posted by LS_GRINDSEASON
Hello all,
Just had the same issue P0155, P0135 and P0498. The fuse is in the driver side fuse box under the dash by your left foot. The fuse is number 4 on the little chart description thing it is labeled LAF and it is a 15 AMP mini fuse blue in color.
Old Sep 6, 2020 | 10:16 AM
Acura_TL2012's Avatar
I also have same problem 2012 Acura TL Check Emission System with DTCs P0498 P0135 P0155? What fuse did you have to replace, please help me out?
Old Sep 6, 2020 | 10:18 AM
what fuse did you replace?
Old Sep 6, 2020 | 10:22 AM
uhh the one that is blown, captain obvious.
you'll need to check EACH and every fuse to see which one has blown.
Old Mar 31, 2021 | 07:59 PM
ehawk01's Avatar
8th Gear
I am having a similar problem. I was looking for a parasitic draw on the battery and pulling fuses to see when the voltage would drop. After finding the circuit with the draw I noticed my CEL on.
I hooked up my diag tool and see PO135 and PO155. I cleared the fault codes and the immediately return. It seems like something is shorted to me since the faults come back immediately. If the sensors were bad, wouldn't it take a few minutes before the fault registered again? Besides Fuse4 where else should I check?
Old Jun 5, 2022 | 03:37 PM
OnlyDaanish's Avatar
I have the same issue now. Did u find where the short was?
Old Jun 6, 2022 | 10:14 AM
peter6's Avatar
Codes are for 2 out of 4 sensors, B1S1 and B2S1.
12V is supplied to all 4 of the sensor through one fuse (under-dash #4 15A) and one relay (also under-dash fuse box).
If relay or fuse is bad (for example because of the short somewhere) you would have codes for all 4 sensors.
Need to get to the sensor and check it out. Good heater would have like 2-4 Ohms. If that passes, back probe the sensor's plug when sensor is connected and make sure it had good ground and good 12v. (might need a bi-directional scan tool to actually force the heater close to 100%)
I think upstream sensors might take more current than downstream, so if there's bad ground or bad power supply, those codes will set before downstream oxygen sensors.
Old Jan 26, 2025 | 06:13 AM
Winkeye's Avatar
P0135 p0155 p0498
Hello all,
How did you fix it I have same trouble any fuse?
Slick Rik
Jul 29, 2011 11:03 AM
Avsfan135
Mar 9, 2011 11:50 PM
Beantown
Feb 26, 2007 04:46 PM
Claymmore
Feb 1, 2007 07:50 PM
SupaCL
May 20, 2006 03:07 PM
