Open car door indicator flashing but car door is closed and car wont lock HELP ASAP
5th Gear
i have a 2004 Acura TL with a issue that is pissing me off. i was walking to my car normally i got in turned it on and the back right door indicatior was saying it was open but i checked and it wasn't and now the lights inside the car don't wanna shut off and also the car doesnt wanna lock i need help asap please thanks
Remove the panel to that door & check if the connector is plugged in securely. If not, then secure it. If it is, remove the plug, check continuity of the switch with a multimeter. If the switch checks out then an adjustment might work. Replacing it should be very easy.
tman570
06-11-2019 07:56 AM
Zonian22
11-14-2015 01:20 PM
Zonian22
09-02-2015 08:19 AM
