Oil/grease on spark plug?
Hi all, I replaced the plugs last week and found one of them has oil/grease just like the picture below. The mileage was about 80k. Any idea of what it is exactly and why it's there?
Thanks!
Thanks!
TLicious Type S
Looks like just discoloration of the insulator material to me--I've seen older plugs do this. Was there actual oil there, or just dry discoloration? The most important thing is what the electrode surfaces look like--should be light gray-brown.
You can also get some "blow by" if the plug was not installed tight enough--usually a black powdery soot.
The only other thing might be a leak in the valve cover coming down into the plug compartment. Good luck.
That brown ring is normal and would normally be on all 6:
The brown ring is normal; it’s nothing more than an electrical charge that is between the porcelain and metal. Dirt and oil mist is being attracted towards the spark plug by the electro-static effect of the high voltages. No problem there.
Now if it were black, I'd venture a guess that the plug was loose and it was a carbon ring.
^^^Yup, perfectly normal. Known as "corona". What would seem to be abnormal is if it's the only plug with a corona....
And what plugs did you use as replacements? If the other plug in the picture is what you used, then you bought the wrong plugs....
acuratl26
04-23-2020 07:30 PM
ITSJESTER
17
12-06-2018 02:29 AM
Joe Avesyan
09-29-2015 03:57 PM
