OBD2 report. Cause of my decreased MPG?
Hopefully someone speaks OBD2.
Recently my MPG has dropped from the high 20s to the high teens. I used to be able to get 30+ mpg cruising along on the freeway, now it struggles to get 26. Im not throwing any CELs and the car is not behaving in any unusual way.
I ran this test through Torque Pro on my smartphone. Here are the results. The failed tests are in bold.
Thanks!
Test report:
MID:$01 TID:$80
- O2 Bank 1 Sensor 1
Max: 40S Min: 0S
Test result value: 25S
PASS
MID:$01 TID:$81
Max: 110Ohm Min: 0Ohm
Test result value: 74Ohm
PASS
MID:$01 TID:$82
Test incomplete or dependant test failed
MID:$01 TID:$83
Max: 3.30859mA Min: -128mA
Test result value: 0.00781mA
PASS
MID:$01 TID:$84
Max: 5.57422mA Min: 1.23438mA
Test result value: 3.81641mA
PASS
MID:$01 TID:$87
MID:$01 TID:$88
MID:$02 TID:$98
- O2 Bank 1 Sensor 2
Max: 65.535V Min: 0.65V
Test result value: 0.786V
PASS
MID:$02 TID:$99
Max: 0.293V Min: 0V
Test result value: 0.131V
PASS
MID:$02 TID:$9a
Max: 1.27V Min: 0V
Test result value: 0.779V
PASS
MID:$02 TID:$9b
Max: 1,320ms Min: 0ms
Test result value: 110ms
PASS
MID:$02 TID:$9c
Max: 65.535V Min: 0.05V
PASS
MID:$05 TID:$80
- O2 Bank 2 Sensor 1
Max: 40S Min: 0S
PASS
MID:$05 TID:$81
Test result value: 75Ohm
PASS
MID:$05 TID:$82
MID:$05 TID:$83
Max: 3.29688mA Min: -128mA
PASS
MID:$05 TID:$84
Max: 5.56641mA Min: 1.22266mA
Test result value: 3.4375mA
PASS
MID:$05 TID:$87
MID:$05 TID:$88
MID:$06 TID:$98
- O2 Bank 2 Sensor 2
Test result value: 0.761V
PASS
MID:$06 TID:$99
Max: 0.293V Min: 0V
PASS
MID:$06 TID:$9a
Max: 1.27V Min: 0V
Test result value: 0.747V
PASS
MID:$06 TID:$9b
Max: 1,410ms Min: 0ms
Test result value: 80ms
PASS
MID:$06 TID:$9c
PASS
MID:$10 TID:$13
- O2 Bank 4 Sensor 4
Max: 4,158 Min: 6,224
Test result value: 22,832
FAIL
MID:$21 TID:$a0
- Catalyst Monitor Bank 1
Max: 784 Min: 0
Test result value: 4
PASS
MID:$22 TID:$a0
- Catalyst Monitor Bank 2
Max: 768 Min: 0
PASS
MID:$28 TID:$5d
Max: 21,845 Min: 21,845
Test result value: 65,525
FAIL
MID:$30 TID:$03
Low sensor Voltage for switch time calculation -
Max: 0.06% Min: 106.73%
Test result value: 655.20001%
FAIL
MID:$30 TID:$0c
Misfire counts for last/current driving cycles(calculated) -
Max: 1,976.55005AFR Min: 372.95001AFR
Test result value: 3,276.15015AFR
FAIL
MID:$31 TID:$d0
- EGR Monitor Bank 1
Max: 0.04014inch Min: 0inch
Test result value: 0.02043inch
PASS
MID:$31 TID:$d1
Max: 1.99882inch Min: 0.00589inch
Test result value: 0.05703inch
PASS
MID:$31 TID:$d2
Max: 655.34998% Min: 342.67999%
Test result value: 426.78%
PASS
MID:$3a TID:$ba
- EVAP Monitor (cap off)
Max: 1,200S Min: 0S
Test result value: 22S
PASS
MID:$3c TID:$b4
- EVAP Monitor (0.040")
Max: 1.84952 Min: 0
Test result value: 0.46726
PASS
MID:$3c TID:$b5
MID:$3c TID:$b6
MID:$3c TID:$b7
MID:$3c TID:$b8
MID:$3d TID:$b9
- EVAP Monitor (0.020")
Max: 100.00641% Min: 0.19991%
Test result value: 0.99953%
PASS
MID:$68 TID:$5d
FAIL
MID:$70 TID:$03
FAIL
MID:$81 TID:$d8
- Fuel System Monitor Bank 1
Max: 1.18682 Min: 0.84326
Test result value: 1.01507
PASS
MID:$82 TID:$d8
- Fuel System Monitor Bank 2
Test result value: 1.02029
PASS
MID:$90 TID:$03
FAIL
MID:$90 TID:$28
Max: -204.72% Min: 270.23999%
Test result value: -0.16%
FAIL
MID:$a2 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 1 Data
Max: 65,535Count Min: 0Count
Test result value: 0Count
PASS
MID:$a3 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 2 Data
PASS
MID:$a4 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 3 Data
PASS
MID:$a5 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 4 Data
PASS
MID:$a6 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 5 Data
PASS
MID:$a7 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 6 Data
PASS
MID:$b0 TID:$03
Max: 0.05% Min: 270.57001%
FAIL
MID:$d0 TID:$03
Max: 0.1% Min: 270.57001%
FAIL
MID:$d0 TID:$28
Max: -204.73% Min: 106.39999%
FAIL
End of report.
Thanks!
Test report:
MID:$01 TID:$80
Max: 40S Min: 0S
PASS
MID:$01 TID:$81
PASS
MID:$01 TID:$82
MID:$01 TID:$83
PASS
MID:$01 TID:$84
PASS
MID:$01 TID:$87
MID:$01 TID:$88
MID:$02 TID:$98
PASS
MID:$02 TID:$99
Max: 0.293V Min: 0V
PASS
MID:$02 TID:$9a
Max: 1.27V Min: 0V
PASS
MID:$02 TID:$9b
PASS
MID:$02 TID:$9c
PASS
MID:$05 TID:$80
Max: 40S Min: 0S
PASS
MID:$05 TID:$81
PASS
MID:$05 TID:$82
MID:$05 TID:$83
PASS
MID:$05 TID:$84
PASS
MID:$05 TID:$87
MID:$05 TID:$88
MID:$06 TID:$98
PASS
MID:$06 TID:$99
Max: 0.293V Min: 0V
PASS
MID:$06 TID:$9a
Max: 1.27V Min: 0V
PASS
MID:$06 TID:$9b
PASS
MID:$06 TID:$9c
PASS
MID:$10 TID:$13
FAIL
MID:$21 TID:$a0
Max: 784 Min: 0
PASS
MID:$22 TID:$a0
Max: 768 Min: 0
PASS
MID:$28 TID:$5d
FAIL
MID:$30 TID:$03
FAIL
MID:$30 TID:$0c
FAIL
MID:$31 TID:$d0
PASS
MID:$31 TID:$d1
PASS
MID:$31 TID:$d2
PASS
MID:$3a TID:$ba
Max: 1,200S Min: 0S
PASS
MID:$3c TID:$b4
Max: 1.84952 Min: 0
PASS
MID:$3c TID:$b5
MID:$3c TID:$b6
MID:$3c TID:$b7
MID:$3c TID:$b8
MID:$3d TID:$b9
PASS
MID:$68 TID:$5d
FAIL
MID:$70 TID:$03
FAIL
MID:$81 TID:$d8
PASS
MID:$82 TID:$d8
PASS
MID:$90 TID:$03
FAIL
MID:$90 TID:$28
FAIL
MID:$a2 TID:$0c
PASS
MID:$a3 TID:$0c
PASS
MID:$a4 TID:$0c
PASS
MID:$a5 TID:$0c
PASS
MID:$a6 TID:$0c
PASS
MID:$a7 TID:$0c
PASS
MID:$b0 TID:$03
FAIL
MID:$d0 TID:$03
FAIL
MID:$d0 TID:$28
FAIL
End of report.
I'm guessing it's a bad O2 sensor. Not sure what the report means by "bank 4, sensor 4". Take your car to any auto parts chain store and get your codes read for free.
FYI, bank 1 is the Cat near the firewall. Sensor 1 is the top (upstream) and sensor 2 is the bottom one. Bank 2 is near the radiator.
