O2 Sensor
Can someone please tell me how I figure out which sensor I need to replace. Bank 2 is the supposed culprit. Trying to figure out which one on Bank 2 to replace. Thank you for any help.
What is the reason for you wanting to replace the O2 sensor? Do you have the DTC (diagnostic trouble code)? You might consider testing the sensor first before replacing it and it not solving whatever problem you're having.
Originally Posted by Vlad_Type_S
(Post 14846587)
A dirty air filter wouldn't cause that code. Before slinging parts at it, try searching for a vacuum leak as that would also cause this code. If there isn't one, I suggest testing the O2 sensors before replacing them. If the O2 sensors are good, I would perform a valve adjustment as this has cleared the P0171 code for some folks on this site (myself included) even though some people think it's impossible and that it was a freak instance/bad tank of gas.
(Post 14847273)
The ECU in our car is very smart... it can adjust to things relatively quickly and adapt well to various conditions. I think it's extremely unlikely that changing the air filter is causing this.
Damn dude, what do you mean by "your timing belt went"? How many miles on the clock? The way I see the possibilities: either a lean condition exists or it doesn't. If it does, it only exists on one bank, so the problem is one that doesn't affect both sides. So it's probably not your MAPS. I think the most common cause of lean codes is a vacuum leak. But it's certainly not the only cause. It might also be a problem with the fuel system on just one rail (not enough fuel), but this is more difficult to troubleshoot. If a lean condition doesn't exist, then your sensor is lying to you (also fairly common) and you'll need to troubleshoot it to find out. |
Long story short, timing belt broke while driving about 45. Didn't completely snap and stayed on all pulleys. Had it done 25,000 prior. So replaced everything again and I guess I got lucky because it is purring like a cat. Runs great. Back to the P0174, friend of mine is an Acura Tech and he just called and said I need a software update. I will try that first and go from there. 2007 Base currently at 135,000.
| All times are GMT -5. The time now is 10:23 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
