Need Help wiring Fog Lights
Old 09-12-2010 | 10:59 PM
Bubz's Avatar
SSgt. Hood
Did a Type S Conversion.
and I need help hooking up the Honda Accord Harness. Can you guys help?
and my car.
Fog lights are just sitting in there LOL
Old 10-03-2010 | 11:16 AM
Bubz's Avatar
SSgt. Hood
still looking for help.
Old 10-04-2010 | 10:30 AM
butnin's Avatar
let me understand something, you did a type S conversion but you want to install a wiring harness from an accord, why?
Old 10-04-2010 | 06:05 PM
elproducto's Avatar
Accord Fogs
I am figuring you have a 04 - 06 TL so
The DYI is located here
https://acurazine.com/forums/3g-tl-2004-2008-93/g-031-diy-accord-foglight-mod-without-removing-spec-bumper-717204/
If you read a little in you should see someone's link to the PDF instructions
I did sort of the same conversion, but did not want to use the Accord harness. I was looking into aftermarket harness or just wiring it up so It would work off the existing fog light wiring. I haven't figured it out all the way yet but got an idea from this post
https://acurazine.com/forums/showpos...6&postcount=46
Thinking of just splicing in H8 Plug with pigtail into the existing fog light wires. I am no electronics expert so I am not sure if it would be possible or not.
While you are doing all that wiring you should also consider doing this mod so you have independent control of your fogs
https://acurazine.com/forums/3g-tl-2004-2008-93/g-029-diy-independent-fog-lights-stock-switch-772633/
Old 10-06-2010 | 11:11 PM
Bubz's Avatar
SSgt. Hood
Looking at this harness I dont think its the right harness. I got it from another member on here.. The harness for the Fogs totally doesnt have the 2-pin connectors.
Old 10-06-2010 | 11:15 PM
EL PESADO's Avatar
x2
InFaMouSLink
10-27-2015 07:51 PM
sockr1
10-01-2015 02:31 AM
ellisd03tls
09-08-2015 05:17 PM
cruisingnycfl
09-02-2015 01:11 PM
prox
5G TLX Problems & Fixes
09-01-2015 03:03 AM
